Re: Valve adj question?
[Re: Cab_Burge]
#1255853
06/23/12 03:06 AM
06/23/12 03:06 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I think you're doing something wrong. There's no way you're "out of adjustment" by that much. You said "1/4 turn of the crank"; You typically want to make adjustments @ 1/2 turns of the crank starting @ TDC.
[Re: StealthWedge67]
#1255854
06/23/12 04:28 AM
06/23/12 04:28 AM
Posts: 174 Oklahoma
hemiiroc
Oklahoma
No ,you do it 1/4 turn at a time
[Re: Jonnyj00]
#1255856
06/23/12 11:37 AM
06/23/12 11:37 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Take the rocker shaft off and place a straight edge across the valve tips. Sounds like you may have tuliped the valves from too much heat. If they are that far gone you should be able to see it with just your eyes,looking across the tips. Keith
[Re: Jonnyj00]
#1255857
06/23/12 11:46 AM
06/23/12 11:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think you messed up on the adjustment... if you had a guide hanging up that bad.. you would have blown up by now(valves crashing the pistons)... JMO
[Re: Jonnyj00]
#1255860
06/23/12 12:13 PM
06/23/12 12:13 PM
MR_P_BODY
Im gonna try and run them again today you never know with it being at the track and it always seems like you forget something when your doing stuff at the track so I could have messed them up. If that dont pan out I am gonna take the rocker shafts off and try and inspect the valves and maybe turn the crank over a bit and use the pushrods to watch those back 4 lifters. Thanks again
Thats why I do the open/closed method.. if someone shows up I just say give me a few minutes so I can finish that side
[Re: Jonnyj00]
#1255861
06/23/12 12:13 PM
06/23/12 12:13 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Did it run ok before the track valve adjustment?
Did you have help and someone confused intake and exhaust?
"Just a Bracket car dressed up like a streetcar"
[Re: tboomer]
#1255864
06/23/12 12:26 PM
06/23/12 12:26 PM
MR_P_BODY
I think that on aluminum heads and an iron block,it is .004-.006 tighter than iron heads on an iron block...But I could be wrong...
.004 works fine... I run a tighter lash than the spec card says... I dont like the big lash so I take out .010 extra
