Re: Electric vacuum pump, suggestions
[Re: Slipknot440]
#1255801
06/23/12 12:25 AM
06/23/12 12:25 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
What does a vacuum pump have to do with getting an EFI equipped vehicle to run right? AFAIK vacuum pumps typically are used to help vacuum assisted components operate when the engine has low vacuum... If your EFI uses a MAP sensor the whole intent is to have it read true engine vacuum which should have a close correlation to engine load & combined with the info from TPS, ACT, ECT & HEGO provides data for fuel trim adjustments...
That is as I said AFAIK.. Now I'll shut up & see what has changed making me wrong....
[Re: Slipknot440]
#1255803
06/23/12 01:53 AM
06/23/12 01:53 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Why not edit your title to mention EFI Tuning concerns & see if a PM to Mopar Rich might attract him to this thread....
My knowledge of EFI is primarily OE stuff so there may be a way to use a vacuum pump but I don't know how...
[Re: Twostick]
#1255807
06/23/12 01:12 PM
06/23/12 01:12 PM
Posts: 3,287 Dalton, MA
Slipknot440
Dalton, MA
Comp cams has it listed as duration (@50) on the intake 230 and lift 566. ( web page ) I am currently making 7.5-8.5 in at idle, warmed up
[Re: Slipknot440]
#1255808
06/24/12 02:01 AM
06/24/12 02:01 AM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I have an MP509 with similar vacuum. To get it to idle consistently I set the ECM to run Alpha Numeric under 1800 rpm. With 76 deg of overlap there is a lot of exhaust reversion into the intake and trying to get it to idle closed loop was futile.
Kevin
[Re: Twostick]
#1255809
06/24/12 10:30 AM
06/24/12 10:30 AM
Posts: 7,664 IN
ahy
IN
Agree as several have posted, the vacuum pump is for accessories only. The ECU nees to see actual manifold vacuum. A pump won't help. The guy who suggested it was in left field. With 230 ish duration at .050 and a 110 cl I would expect manifold vacuum to be higher with 426+ inches. I don't know the rest of your combo but it sounds like a Hemi as its a hemi cam. How about the EFI? What type is it? For reference, I'm running EFI with a 243@.050 cam with 108 lobe seperation on a 496 and it idles well at 800-900 RPM with around 13" vacuuum. I'd start with the tuning. As a guess, you will want 16-20 degrees advance at idle and AF in the mid to low 14's to get best idle. If you get those dialed in I bet it runs better and pulls more vacuum.
[Re: 1_WILD_RT]
#1255810
06/24/12 11:47 AM
06/24/12 11:47 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Just saw this thread. First off - what EFI system are we talking about? If it's an XFI system, that can be tuned to work with any vacuum level. If it's an EZ-EFI then the tech guy was probably trying to cover that the EZ is sensitive to low vacuum conditions. But as already stated, an external vacuum pump will do nothing! The only time an external vacuum pump MIGHT help - A LITTLE, and we're stretching here - is when a vacuum brake booster and a PCV valve are both being used and the brakes drain the vacuum tank quickly. The external vacuum pump can be used to run those leaving the EZ-EFI to see only manifold vacuum
I think they need a new tech guy.
[Re: Mopar_Rich]
#1255811
06/24/12 02:03 PM
06/24/12 02:03 PM
Slipknot440
Dalton, MA
It's an EZ EFI system. So far this week I found a small vacuum leak, adjusted the timing and am currently waiting for a buddy to show up with a spare ignition box to see if my box is the issue (has less than 200 miles on it so it should be fine). My alternator is making all of 60 amps, my voltage regulator is a later model one (for the upgraded wiring harness) as well as the distributor and ecu. My hemi is iron head, iron block, forged pistons, steel crank, stock bore, roller cam. WASTED too much time and too much unforseen money on this thing so far.
[Re: Mopar_Rich]
#1255814
06/28/12 01:00 AM
06/28/12 01:00 AM
Twostick
Still wishing...
Still wishing...
No. Alpha-N used to be used only for race applications on engines that produce very little vacuum. But it was impossible to street tune an Alpha-N system.
Do you mean to tell me that my Holley system actually has something useful in it?? I can set it to run A/N for idle and then it goes speed density after 1800. It plays much nicer with my MP509 now.
Kevin
