Smallblock cam installation question #1255789
06/22/12 11:47 PM
06/22/12 11:47 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
I'm doing a basic rebuild on my 360. New 9-1 pistons, fresh heads and a Sealed Power cam. Specs on the cam are .445/465 lift and duration at .050 is 214/224. I just read an article in a Mopar Muscle from Jan 2008, where they did a bucks down rebuild on a stock 318. When they reassembled it, they upgraded to a 4 barrel carb and a Comp PN 20-223-3 cam. their cam specs .477/.480 and duration at .050 is .224/.230. They used a stock timing chain and installed it straight up. They never degreed the cam. So, I am wondering if it's necessary to degree my cam or not. I don't want to have to spring for a degree wheel, mag base and dial indicator if it's really not necessary and I don't want to pay the machine shop for something I can do myself. Just trying to get a general consensus. Will I be alright or am I asking for trouble?
Re: Smallblock cam installation question [Re: elmor] #1255790
06/22/12 11:50 PM
06/22/12 11:50 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
I would check it, "dot to dot" can be off by 14 degrees or more, if you want me to bring my tools down and check it with you shoot me a PM
Re: Smallblock cam installation question [Re: Baxter61] #1255791
06/22/12 11:56 PM
06/22/12 11:56 PM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
I bought an after market roller chain with 3 keyways on the crank and was going to instal it straight up. I really appreciate your offer and may take you up on it when I start putting it back together.
Re: Smallblock cam installation question [Re: elmor] #1255792
06/23/12 01:58 AM
06/23/12 01:58 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Whatever you do, if lining up the "dot" on the 3 way kit, line up the CORRECT dot. NOT the dot at keyway. It will be the dot about 3 teeth away from keyway, that you will line up with cam dot.
