Does an open carb spacer hurt mpg?
#1255711
06/22/12 05:56 PM
06/22/12 05:56 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Like the title says, does a spreadbore to squarebore adapter on a dual plane intake hurt economy? I'm trying to sety 78 Fury up with a 6322S Thermoquad and just can't get the mileage dialed in. WOT it pulls like a freight train, no bog, no hesitation. It runs like EFI. I'm running a 9.25:1 360, Magnum heads, XE256 cam, dual plane M1, headers into 2.5" exhaust, A500, 3.92 gears. The carb has 1966 rods, .095" primary jets, and .143" secondary jets. City and hwy mpg isn't great. I've tuned the rods from the point of a lean cruise miss, to about 1 7/8 turn up. Just for testing purposes, I put on a Carter 9635SA AFB, with .098 primary jets and 71/47 rods, and .100" rear jets. The car lost a ton of power for some reason with the AFB, but gave huge gains in mileage.
I don't prefer one over the other in the long run, but if I can't tune the TQ, I'm gonna have to use the AFB. Is the 625 AFB too small for a build like this? It's a very tame engine, and if I can get the AFB to keep its mpg, but pull like the Thermoquad, ill keep it. Any ideas?
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: Does an open carb spacer hurt mpg?
[Re: 69L78Nova]
#1255712
06/22/12 06:05 PM
06/22/12 06:05 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
in theory,the t/q should show better mpg,and low end power/tq,,from its small primarys,as with the q-jet from gm.but if either carb is not up to specs,or its engine,that will screw with the mpg right quick.have you tried jetting and timing advance inc vacuum advance too.check and make sure the engine is al up to snuff w/ timing ign ect,and try and customize each carb to the engine,w/ jetting,ect.oh the dual exhaust dont help the mpg's also....mike
[Re: imfixinmopars426]
#1255713
06/22/12 07:07 PM
06/22/12 07:07 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I'd be interested in your AFB if you end up getting the TQ to work... I still can't get over 14.5 mpg with my old 625 AVS on a 318, and I'm exactly one step above a lean stumble at cruise.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: 69L78Nova]
#1255714
06/22/12 10:08 PM
06/22/12 10:08 PM
Posts: 43,287 Bend,OR USA
Cab_Burge
I think, if you measure the primary throttle blades on both carbs., you may be suprised The venturi boosters on the Thermquad should be the limiting factor on the CFM on the primary barrels, not the throotle blade sizes What do you mean when you say you tuned the rods up 1 7/8 from a lean cruise miss? If I'm remembering correctly the Carter 9635SA is a 500 CFM carbs, isn't it?
[Re: Cab_Burge]
#1255715
06/22/12 11:20 PM
06/22/12 11:20 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I mean I've tuned the metering rods on the Thermoquad from all the way down to a lean cruise stumble, to about 1 7/8 turns above that point, in 1/8 turn increments. The 6322s is a 1.5" primary carb off of a 73 440, that shares the same primary and secondary size in addition to identical rod/jet sizes as some of the early 340s and 360s. I don't have a wideband yet, so for "plug tuning", should I be a light brown color after a steady cruise? This TQ just runs so strong, I'd love to make it work. And no, the 9635sa is advertised as a 625cfm
[Re: SomeCarGuy]
#1255717
06/23/12 03:40 AM
06/23/12 03:40 AM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well with the Thermoquad, I'm averaging 12/16. With the AFB, I'm at 16/19. I don't mind the AFB. It's great for daily driving and mileage, its just nowhere near the Thermoquad in terms of performance. This is my daily driver, so I'd really like to iron it out
[Re: 79powerwagon]
#1255719
06/23/12 12:27 PM
06/23/12 12:27 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
What advantage does the 4-hole have over an open insulator gasket? With the AFB, I run the thick open insulator gasket that Edelbrock recommends. With the Thermoquad, its just a cheap Mr Gasket spreadbore/squarebore adapter
[Re: 69L78Nova]
#1255720
06/23/12 12:31 PM
06/23/12 12:31 PM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
Have you tried limiting when the secondaries kick in with the TQ???
The reason I ask is you indicate great power, with the TQ, and the AFB has a much more limited "over-center" weighted mechanism for its secondaries.
You may just want the secondaries to come in later with the TQ.
[Re: 69L78Nova]
#1255721
06/23/12 02:58 PM
06/23/12 02:58 PM
Posts: 27,728 places
79powerwagon
places
My extensive use of AFB style carbs has taught me that they work better on top of a 4-holer than open (on a driver engine, not race-only). Also, Edelbrocks own tech manual states to use a 4-holer. The thickness matters, and I have a pile of 1/4" paper ones that I stack up until I find the sweet-spot, then buy a phenolic that thickness.
[Re: hooziewhatsit]
#1255723
06/23/12 07:24 PM
06/23/12 07:24 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Here's a pic of the #1 spark plug after a steady 10 minute cruise at 1600rpm with the Thermoquad. All eight plugs look the same, with just a slight spot of tan on one part of the porcelain, and the rest of the porcelain is white as can be, all the way down. They are the correct Champion RC12YC plugs for the Magnum heads. I know being too lean could hurt economy. Does this plug look like it needs to be fattened up a little bit? I know I need to get a wideband setup for it when funds permit, I'm just trying to get it in the ballpark for now.
[Re: 69L78Nova]
#1255724
06/24/12 07:56 PM
06/24/12 07:56 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Any opinions based on the pic?
[Re: Mr.Yuck]
#1255727
06/25/12 03:11 PM
06/25/12 03:11 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
440? The question was regarding my Fury, which is running a Magnum head 360. The details are up at the top of this page, in my first post
