Pretty cool resto tip #1255247
06/21/12 07:34 PM
06/21/12 07:34 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
I get the Rockauto newsletter and it had this tip in it for restoring plastic. Hope you guys like it:
Tired of breaking the old, brittle plastic clips that hold on exterior and interior trim? Worried that the plastic thermostat housing will either leak or crack after being over tightened? Hoping for a way to rejuvenate the yellowed plastic gears, slides and rollers in that window regulator? Having trouble sliding the plastic handles onto the metal rods that came with that new foosball table? The answer to these and other plastics conundrums is an elixir available at the nearest kitchen sink.
My dad was a plastics engineer for 30+ years. One of the best tips he has given me thus far is to rejuvenate and limber up old and new thermoplastic polymers by soaking them for a minute or so in boiling water. The results with nylon can be especially dramatic. Yellowish nylon goes into the water brittle and comes out supple and milky white. New composite thermostat housings, foosball table handles, and other plastic pieces that must be mounted to metal become slightly more flexible and are an easier and better fit.
The boiling water does not melt the plastic. Soaking nylon in room temperature water for a long time has the same impact as a short bath in boiling water. The chemistry is too complex for just the son of a plastics engineer to explain. Basically the moisture releases tension between polymer molecules that was created when the plastic was first made (molded, extruded, etc.) or that built up over time as the plastic was exposed to sunlight, heat, chemicals or otherwise aged.
Over the years I have only seen good results from putting my plastic parts in boiling water. At worst the plastic seems unaffected, probably a thermoset plastic (rigid body parts, distributor caps, Bakelite, etc.). However, there are myriad plastic resin recipes and plastic products out there and I must include a disclaimer and encourage common sense and caution. Do not soak plastic pieces that include electronics, gaskets, lubricants, paint, adhesives, decals, etc. that are not supposed to be exposed to water. Do not bring a plastic part out of a freezing garage and immediately dunk it into a boiling pot of water. Thin, molded plastic pieces like interior trim or milk jugs might lose their shape if exposed to heat. Heat and moisture from boiling water might not be uniformly transferred through very thick plastic pieces. If you are at all concerned about the temperature of boiling water, then maybe instead try soaking the plastic piece in unheated water for a day or two. Don’t boil a greasy composite valve cover in your spouse’s favorite spaghetti kettle…
Link:
http://www.rockauto.com/Newsletter/index.html
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Pretty cool resto tip [Re: Dixie] #1255248
06/21/12 07:41 PM
06/21/12 07:41 PM
california
Mr D21 Offline
Mr D21  Offline
california
thanks for the tip - lets see what happens on my windshield fluid bottle !!!
Re: Pretty cool resto tip [Re: Mr D21] #1255249
06/22/12 11:50 AM
06/22/12 11:50 AM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Let us know how it works I have a overflow bottle just begging for a dunking.
What was I thinking....
Re: Pretty cool resto tip [Re: 72blubird] #1255250
02/08/14 12:09 AM
02/08/14 12:09 AM
niagara, ontario
gers1968rt Offline
gers1968rt  Offline
niagara, ontario
Anybody try this?
Re: Pretty cool resto tip [Re: gers1968rt] #1255251
02/08/14 12:30 AM
02/08/14 12:30 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
This is pretty interesting, I would how a speaker grille or the defrost vents would do? Plastic door panels? This could get fun.
Careful, your character's showing!
Re: Pretty cool resto tip [Re: mopar346] #1255252
02/08/14 01:39 AM
02/08/14 01:39 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Yes I tried this several years ago on bumper fillers for a74 charger and they are still limber. ( pliable)
Re: Pretty cool resto tip [Re: 340cpe] #1255253
02/08/14 01:03 PM
02/08/14 01:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well, being in the engineered plastics business I can tell you that yes, this works. But don't expect miracles because it does have limitations - it won't make a 40-year old windshield resevoir new again.
The improvement comes more from "heat soak" than moisture as virtually every plastic has extremely low moisture absorption rates - usually less than .05% over a 24 hour period.
Re: Pretty cool resto tip [Re: Stanton] #1255254
02/08/14 01:19 PM
02/08/14 01:19 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I will try this before I put on the 3" trim clips for the side moldings on my 69 Monaca 500 convertible!
JB Rhinehart, Realist
A-Body's RULE!
Re: Pretty cool resto tip [Re: 340cpe] #1255255
02/09/14 10:52 AM
02/09/14 10:52 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Now there's something I can use! Thanks.
Re: Pretty cool resto tip [Re: Commando1] #1255256
02/13/14 12:01 PM
02/13/14 12:01 PM
S.W. Florida
blkbee6pack Offline
blkbee6pack  Offline
S.W. Florida
Will this work on 1970 coronet ft. bumper fillers?
