Re: Checked my bellhousing alignment....
[Re: 70HemiGTX]
#1255202
06/21/12 07:52 PM
06/21/12 07:52 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
What block and bell housing? Stock pins in it right now? Is this a new combo for these parts or is this just the first time you checked it?
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1255204
06/21/12 11:11 PM
06/21/12 11:11 PM
Posts: 7,664 IN
ahy
IN
.061" is a lot! Before correcting the axial alignment, suggest you check the transmission mounting face with your indicator for face runout. It is corrected with shim stock between the housing and block. Correcting the face alignment will change the axial alignment... and may bring it in closer. The biggest offset dowel I know of is .021" to correct .042" of runout.
For dowels, I've had best luck with the simple type. Mancini sells them under the MP brand.
PS: With the Lakewood housing you have another option. You can get weld on bushings to carry the dowels. You drill the existing dowel holes on the housing oversize, snug the mounting bolts, tap the housing into correct alignment then weld the bushing on with a straight dowel holding it in place.
[Re: dartman366]
#1255206
06/22/12 04:05 AM
06/22/12 04:05 AM
Posts: 2,364 PA
70HemiGTX
PA
to make things easier, zero your indicator at the 12:00 position then sweep the bore making sure you are not running off the edge of the opening also use a large button or round tip on the indicator I do not suggest using any type of pointed tip as they have a tendency to pick up any roughness and will catch knocking the indicator out of alignment, also to check that the indicator didn't move on you always make sure it go's back to zero in the 12:00 position.
I was using the pointed tip. I thought about the rounder tip, but am new to this stuff. I'll try the zero deal also. Thanks!
[Re: 70HemiGTX]
#1255207
06/24/12 09:33 AM
06/24/12 09:33 AM
Posts: 2,364 PA
70HemiGTX
PA
Ok guys, I have some new numbers... On the face of the bellhousing where the trans bolts to I got these #'s. 12:00 -.008 3:00 -.009 6:00 -.002 9:00 0.000 So there is an issue there. I'll take the housing and block plate off and make sure there aren't any globs of paint on the mounting surfaces. For the axial alignment of the bellhousing, I'm getting these #'s. 12:00 +.0585 3:00 +.055 6:00 0.000 9:00 +.004 another set 12:00 +.032 3:00 +.002 6:00 -.036 9:00 0.000 I zeroed the dial indicator and brought it back to my 0.00 point to make sure it was accurate. It 0.00'd out every time. I never thought it would be this difficult!
[Re: 70HemiGTX]
#1255208
06/24/12 10:29 AM
06/24/12 10:29 AM
dartman366
Mt. Vernon, Ohio
I agree with cleaning the mating surfaces, alto I do not know an acceptable amount of runout, I assume you get it as close as possible, but how much out of paralell to the block surface is acceptable?? as far as the runout of the locating bore, looks good side to side, but need's to move up about .017 to center it, that should be easily obtainable with the off set dowels.
