Re: reverse manual valve body engine flare up
[Re: dvw]
#1254881
06/21/12 08:30 AM
06/21/12 08:30 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
If the cable is adjusted correctly then the 3rd/reverse clutch is damaged. I would double check the cable , pull the bolt that attaches the cable when it's in 3rd gear. The bolt should come out easily and not be in a bind when the adjustment is correct. Doug
[Re: 6pakdakota]
#1254882
06/21/12 10:20 AM
06/21/12 10:20 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I would think your cable adjustment is wrong... also while your at it re-adjust the bands when your under there
[Re: dartman366]
#1254886
06/21/12 04:36 PM
06/21/12 04:36 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
you can tighten the band 1/2 turn and that will help it,, but you burned the front clutch pack up,, its applying late,, the band releases and and the clutch applies,, though late,, so it flares
[Re: dvw]
#1254888
06/21/12 09:00 PM
06/21/12 09:00 PM
moderncylinder
detroit area
doug,, the band is applied in 2nd gear,, it comes off the drum going into 3rd and the clutch applies,, if the cluth is slow to apply cause its worn out or loose it will flare the 2-3 gear change,, if the band is too tight it will pull down on the 2-3 gear change,, the timing of the band releasing and the foward clutch applying is something you just learn what works for your set up,, as to how many turns out your band is,, im at 2 1/4 turns out,,,, but i recently burned up the forward clutch and it flared in the 2-3,, i tightened the band 1/2 turn and it fixed it,, took trans apart and the clutches were smoked,, causing a delay in it applying,, which is why,,, it flared..
[Re: moderncylinder]
#1254889
06/22/12 02:09 AM
06/22/12 02:09 AM
dartman366
Mt. Vernon, Ohio
been there done that, yes you probably hurt the high gear clutch eather burn't it or wore it enough to change the timing of the shift event.
[Re: dartman366]
#1254890
06/22/12 02:23 AM
06/22/12 02:23 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
if a clutch was burnt or worn could you tell if you dropped the pan?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#1254891
06/22/12 02:37 AM
06/22/12 02:37 AM
dartman366
Mt. Vernon, Ohio
usually if it is burn't the fluid will have a burn't smell and will not have that pretty red color to it may have some dark looking residue in the pan, if it's burn't bad enough you will know pretty quickly by smell alone, dissasembly will verify wear as the clutch clearance will have opened up.
