replacing "69 coronet rear frame rails #1254559
06/20/12 09:29 PM
06/20/12 09:29 PM
Columbiaville, New York
birdsandbees Offline OP
I have a "69 coronet that needs all metal replaced behind the rear seat.Having never done body work before,can you experienced guys give me some tips on how to replace rear rails.Can't afford to have a shop do it so I need to know what I am getting into. Thanks
Re: replacing "69 coronet rear frame rails [Re: birdsandbees] #1254560
06/21/12 10:58 AM
06/21/12 10:58 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
frame rail replacement is not really for a novice
but it is not impossible for a novice to learn how.
you are getting in as deep as you can go..
do you have any welding experiance?
own a welder?
if not,get yourself a decient entry level machine
and start practicing before you go near a car.
your best fitting replacement metal will come from other donar cars
do you have the parts you need to replace?
if not, start hunting...
when you have a large area to replace like 2 rear rails
your best way to attack it is to replace what is bad
by what is called a clip.
you would keep the donar rails together as a unit and replace both rails at the same time.
the more parts you keep together from the factory
the more likely everything will line up when you put it back together.
also you will need to learn how to extract parts without
hacking them up.
you will also need a good spotweld drillbit
for that task.
good luck,you have a very large hill to climb!
keep asking questions on here will be your best help..
Re: replacing "69 coronet rear frame rails [Re: flypaper] #1254561
06/21/12 12:07 PM
06/21/12 12:07 PM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
Measure, measure, and measure some more.
If you don't get the rails just right, you'll have issues with panel fit/alignment and dogtracking
Re: replacing "69 coronet rear frame rails [Re: Paul] #1254562
06/21/12 12:26 PM
06/21/12 12:26 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
I would either replace the whole clip or keep saving to have it done by someone with experience and a frame table.
Everybody makes fun of a hillbilly until they need something fixed
Re: replacing "69 coronet rear frame rails [Re: B_Body_Bob] #1254563
06/23/12 08:34 AM
06/23/12 08:34 AM
Thanks for all the advice guys,,,I have been welding for 20 years and I just found a guy with a frame table so I hope he will be able to help me.Thanks again....MOPAR DAN
Re: replacing "69 coronet rear frame rails [Re: flypaper] #1254564
06/23/12 01:03 PM
06/23/12 01:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'll just throw this in as it should help...
Re: replacing "69 coronet rear frame rails [Re: birdsandbees] #1254565
06/23/12 01:17 PM
06/23/12 01:17 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
If you havent done it before I advice to use only original parts from a donor car. Repro parts may always have some differences in dimensions, shape, etc. that can lead you in the wrong direction if you have never done it before.
Factory sheetmetal will drop into place...its a no brainer.
Measure a lot before you cut, make diagrams, etc. Common sense will tell you how to do it, its not hard to do. Just dont rush it.
Building a jig from sqare tubing, make it fixed into place on the ground so it never moves, brace a lot before you cut, measure taking reference points to the ground or to the jig, or to other points on the car, replace the complete rear clip if possible, not separate parts off a donor car, it's easy if you start out right.
Check my HEMI Charger restoration. Lots of pics there, I had to do the same on my car. Looks like a factory installation you cant tell anything has been replaced on my car!
http://www.facebook.com/1969.hemi.charger
Domingo
Re: replacing "69 coronet rear frame rails [Re: domingo] #1254566
06/23/12 01:21 PM
06/23/12 01:21 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
http://www.facebook.com/media/set/?set=a...e=3&theater
keep clicking on the pics forward or aft to see all the restoration step by step.
Re: replacing "69 coronet rear frame rails [Re: domingo] #1254567
06/23/12 01:25 PM
06/23/12 01:25 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Re: replacing "69 coronet rear frame rails [Re: domingo] #1254568
06/23/12 01:45 PM
06/23/12 01:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Sorry Domingo but there's been a serious shortage of that lately...
Re: replacing "69 coronet rear frame rails [Re: 1_WILD_RT] #1254569
06/23/12 04:00 PM
06/23/12 04:00 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
LOL
Re: replacing "69 coronet rear frame rails [Re: 1_WILD_RT] #1254570
06/23/12 05:02 PM
06/23/12 05:02 PM
thanks 1_WILD_RT,This will really help.
