Re: Megasquirt set up questions (MPFI BB)
[Re: 68Bullet]
#1254362
06/20/12 06:35 PM
06/20/12 06:35 PM
Posts: 2,256 IL
furious70
IL
Do you have a lean burn dizzy and/or did you lock out the mechanical advance and leave the vac adv unhooked? I use a lean burn 400 dizzy to trigger my classic FAST efi in inductive pickup mode.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Twostick]
#1254368
06/23/12 01:49 PM
06/23/12 01:49 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
My 360 MS2 is set up through a 7 pin HEI module so the computer can control timing. I figured it was best to isolate the wiring away from the computer itself, and let the HEI do all the work. I did have to turn on some noise filtering to get a smooth RPM signal. Have you adjusted the pot on the main board? Using the VR input directly from the distributor requires some adjustment IIRC.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
