These 451 Pistons Good ? #1254356
06/20/12 02:37 PM
06/20/12 02:37 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
Hello. Slowly Purchasing The Parts For A 451 Low Deck Build & Wanted To Hear Opinions On These Pistons. Am Trying To Keep A Budget Of $500.00 For The Pistons & These Fit That Criteria, Also Want The .990 Pins. So, Anyone Have Input On This Choice? Thanks
http://www.ebay.com/itm/190550585780?_tr...r#ht_1651wt_698
Re: These 451 Pistons Good ? [Re: titan] #1254357
06/20/12 02:53 PM
06/20/12 02:53 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
More info would be needed but the SRP is a sportsman's race piston from the folks at JE. They will work fine for most all except the most demanding applications
Re: These 451 Pistons Good ? [Re: Maximus_Wedges] #1254358
06/20/12 05:11 PM
06/20/12 05:11 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I am running srp pistons from JE and they seem to be really good quality.
67' charger 499 RB 10.57 at 127
Re: These 451 Pistons Good ? [Re: dragram440] #1254359
06/20/12 07:01 PM
06/20/12 07:01 PM
dogdays Offline
dogdays  Offline
The pistons themselves are jewels and you'll love them. They are 4032 alloy which means you can run a little tighter piston/cylinder wall clearance, the only time they'd not be really good is if you are doing a max effort engine possibly with a big load of nitrous. Then a 2618 piston would be better, but all the TRW/Speed Pro pistons over the years have been 4032 or a similar alloy.
R.
Re: These 451 Pistons Good ? [Re: dogdays] #1254360
06/20/12 07:08 PM
06/20/12 07:08 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I cant comment on the pistons from experience, but I have bought some stuff from the same vendor. I recommend him 100%
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
