Found a interesting part and now can't find it again... #1254241
06/20/12 10:24 AM
06/20/12 10:24 AM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
The other day I was looking through parts on the net and came across something like an electric oil pump primer. First time I had ever seen something like this. I think it gets spliced into your oil lines.
It was advertised as if after you have primed your engine and have to sit in the pits for 30-40min you could use this to keep your prime. It wasn't a accumsump or anything like that but almost an electric oil pump. It talked about no more push rod gauling ect.
Not sure who made it or where I saw it but now I want it!!!
Thank for any help
Doug
Re: Found a interesting part and now can't find it again... [Re: Diablo] #1254242
06/20/12 12:15 PM
06/20/12 12:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Be nice for us bracket guys to to circulate trans fluid between rounds to better cool the trans. I know ARI makes a pump that mounts to the trans. Woudl like to find something as you describe for sure.
Re: Found a interesting part and now can't find it again... [Re: Al_Alguire] #1254243
06/20/12 08:09 PM
06/20/12 08:09 PM
Des Moines, IA
CoreyWilson Offline
CoreyWilson  Offline
Des Moines, IA
Not sure on the pricing or if these would even keep up with the demand or be able to be plumbed in, but after a little searching I ran across this
http://www.rbracing-rsr.com/oilsystems.htm
Re: Found a interesting part and now can't find it again... [Re: CoreyWilson] #1254244
06/20/12 09:56 PM
06/20/12 09:56 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
This has got to be what your looking for. neatest thing i have seen in a while and no need to do anything special.
http://www.petersonfluidsys.com/filter_mount.html
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Found a interesting part and now can't find it again... [Re: Al_Alguire] #1254245
06/21/12 02:10 AM
06/21/12 02:10 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The Petersn piece is nice. If I had a spin on filter on my dry sump I woudl have one. Sure beats fighting the 90 degree drill priming it now.
