jeep auto trans pan leak #125392
09/24/08 07:01 AM
09/24/08 07:01 AM
So.IL.Home of Popeye
P
plum340demon Offline OP
P
Changed the filter and oil in my 02 wrangler 6cyl auto.The original gasket was made of steel with gasket material on both sides.I went to napa and got a kit that had a rubber gasket in it,it said to use no sealer.Well it has a small leak,pan is in good shape and tight.Do u guys use sealer on the gasket or should i try to get a mopar gasket.
Re: jeep auto trans pan leak [Re: plum340demon] #125393
09/24/08 04:51 PM
09/24/08 04:51 PM
Omaha,Nebraska
johncambridge Offline
super gas
super gas
Omaha,Nebraska
Your original gasket should be re-usable.
BAXTER CHRYSLER JEEP DODGE - OMAHA,NEBRASKA 800-642-1524 - 402-493-0116 - PARTS@PERFORMANCEAUTO.COM MOPAR PERFORMANCE, RESTORATION PARTS TTi HEADERS AND EXHAUST DISTRIBUTOR LEGENDARY INTERIORS DEALER AR ENGINEERING DEALER
