is this agood cam for street car? #1253904
06/19/12 06:54 PM
06/19/12 06:54 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
purple p4120661 296/296 557/557
Re: is this agood cam for street car? [Re: CUDA8U] #1253905
06/19/12 07:08 PM
06/19/12 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
no
Don't be the exception.
Re: is this agood cam for street car? [Re: Supercuda] #1253906
06/19/12 07:11 PM
06/19/12 07:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No vacuum, very lumpy idle and a power band way up in the rpm range. Not a streetable cam.
Re: is this agood cam for street car? [Re: stumpy] #1253907
06/19/12 07:24 PM
06/19/12 07:24 PM
Renton Washington
Triple Threat Offline
Renton Washington
It's all relative, that one is smaller than the one in my Dart that I drive on the streets.
Depends on what its going in and what you expect it to do.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: is this agood cam for street car? [Re: stumpy] #1253908
06/19/12 07:45 PM
06/19/12 07:45 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
With the right components..........
it would be fun.
3400+ stall, dual-plane Edelbrock RPM, 750 carb, 4.10 or + gearing, 1.75 or + headers, you get the idea. Match components added and it would scream on the street.
Re: is this agood cam for street car? [Re: Dean_Kuzluzski] #1253909
06/19/12 08:10 PM
06/19/12 08:10 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I really like it in my 408 demon. It is a 4 speed, 4.11 gears, mildly lightened. With ootb edelbrock heads, 1 5/8" headers, and an air gap/750dp it quit pulling before 6000 rpm. It is noticably softer on the bottom end than the approx 235*@.050/ .525" lift hydro flat tapppet cam it replaced, which actually makes the car way easier to start and drive in normal traffic- you have to rev it up a little to get to the power. Below the powerband it might not have the torque of the smaller cam but it drives very nice and smooth, no jerking around before the cam hits.
I like it for now and I'm not planning to swap again without going roller.
Re: is this agood cam for street car? [Re: radar] #1253910
06/19/12 08:27 PM
06/19/12 08:27 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
I m currently running it in my street 440. It will idle between 600-750rpm with good carb tune, lots of lope. I have a single plane and vacuum 2ndarys, It wont roast them from a dead stop with out a lot of rpm, but it will climb as far as you want to take it on the street!
So again, all depends on what your looking for.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: is this agood cam for street car? [Re: kilroy] #1253911
06/19/12 08:32 PM
06/19/12 08:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
just because a car is driven on the street doesn't mean it is a street car.
Any cam will act milder the bigger the engine it is in. More compression helps. Deeper gears help. Stick is easier than an auto. More stall helps. lighter weight helps. ALL of those move it farther from street till you get to "not a street car".
Since you neglected to mention any details about the vehicle, engine, trans, gears etc you cannot expect an answer that is relevant.
Re: is this agood cam for street car? [Re: radar] #1253912
06/19/12 09:22 PM
06/19/12 09:22 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
......it quit pulling before 6000 rpm.
That does not seem right
Re: is this agood cam for street car? [Re: BSB67] #1253913
06/19/12 09:29 PM
06/19/12 09:29 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
It's all relative, no two people are alike in what they consider streetable. My street cam is 288/292@.050, of course my convertor stalls around ~5600 and I run 4.56 gears and the motor is 605ci.Dave
Re: is this agood cam for street car? [Re: quickd100] #1253914
06/19/12 09:34 PM
06/19/12 09:34 PM
IN
ahy Offline
ahy  Offline
IN
Fit of the cam depends a lot on the rest of the combo... cubes, compression, transmission, rear. Also on applicaiton... mostly strip with a little street or vica versa. Some more info would help.
Re: is this agood cam for street car? [Re: BSB67] #1253915
06/19/12 10:06 PM
06/19/12 10:06 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Ya thats not right, course he had it on a sb so the heads could have been the limit.
On my 440 it is really pulling hard at 6k.
He also asked about the '661' cam so I guess I assumed he was talking about some for of BB.
Re: is this agood cam for street car? [Re: kilroy] #1253916
06/19/12 10:13 PM
06/19/12 10:13 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
well thanks guys,I realize it's an open ended question with all my specs etc
gears 3:55
stall 2800
manual steering/brakes but may ad power steering
10-1 comp
i just stumbled upon this cam in a local ad and thought I'de ask
thanks again
Re: is this agood cam for street car? [Re: CUDA8U] #1253917
06/20/12 12:45 AM
06/20/12 12:45 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
gears 3:55
stall 2800
Nope, that's too much cam for those gears and converter
Re: is this agood cam for street car? [Re: DrCharles] #1253918
06/20/12 12:59 AM
06/20/12 12:59 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
gears 3:55
stall 2800
Its how I used to drive it when I had an auto.
just stay in low a little longer.
Re: is this agood cam for street car? [Re: CUDA8U] #1253919
06/20/12 01:24 AM
06/20/12 01:24 AM
organ
maximum entropy Offline
organ
too small in my 496. how big are you? big engine, go big. that cam in an 8:1 340 would be a turd on the street.
Re: is this agood cam for street car? [Re: maximum entropy] #1253920
06/20/12 02:36 AM
06/20/12 02:36 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
mine is a 440 ....450-500hp
Re: is this agood cam for street car? [Re: CUDA8U] #1253921
06/20/12 08:16 AM
06/20/12 08:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
gears 3:55
stall 2800
10-1 comp
thanks again
No it's not a street cam, unless your idea is driving it to the track and racing it and second it will not work well w/ what you have. If i were you I'd look in the 480-490ish range and something around 220 @ .050
Coming soon!!!!
Re: is this agood cam for street car? [Re: Mr.Yuck] #1253922
06/20/12 08:30 AM
06/20/12 08:30 AM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
I drive a car with that cam almost everyday when its dry out, off 1k idle to 7200 smooth even torque cam. But ive alot more vert and deeper gears.
Its really one of the most streetable cams ive used.
Re: is this agood cam for street car? [Re: CUDA8U] #1253923
06/20/12 11:13 AM
06/20/12 11:13 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I had a MP 360 shortblock once that I put a 557 in. I had stock Edelbrock heads on it,1 5/8 headers,3000 stall convertor,3.91 gears.
Was in our street/strip Duster.
I drove it to work whenever it was nice out,my wife drove it to the local track every week and ran it in the local points races. Ran a best of 11.79.
The car had 3" exhaust with Flowmaster Delta Flow mufflers. That thing got more compliments and turned more heads on the street due to the way it sounded than anything else I ever had.
Streetability is all dependant on the owner.
As A sidenote,my wife came in second in our street class with it her first year ever racing,the next year she moved up to the Pro class and tied me in points.
Keith
