Re: is this agood cam for street car?
[Re: stumpy]
#1253907
06/19/12 07:24 PM
06/19/12 07:24 PM
Triple Threat
Renton Washington
It's all relative, that one is smaller than the one in my Dart that I drive on the streets.
Depends on what its going in and what you expect it to do.
[Re: radar]
#1253910
06/19/12 08:27 PM
06/19/12 08:27 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
I m currently running it in my street 440. It will idle between 600-750rpm with good carb tune, lots of lope. I have a single plane and vacuum 2ndarys, It wont roast them from a dead stop with out a lot of rpm, but it will climb as far as you want to take it on the street!
So again, all depends on what your looking for.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#1253911
06/19/12 08:32 PM
06/19/12 08:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
just because a car is driven on the street doesn't mean it is a street car.
Any cam will act milder the bigger the engine it is in. More compression helps. Deeper gears help. Stick is easier than an auto. More stall helps. lighter weight helps. ALL of those move it farther from street till you get to "not a street car".
Since you neglected to mention any details about the vehicle, engine, trans, gears etc you cannot expect an answer that is relevant.
[Re: radar]
#1253912
06/19/12 09:22 PM
06/19/12 09:22 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
......it quit pulling before 6000 rpm.
That does not seem right
[Re: CUDA8U]
#1253917
06/20/12 12:45 AM
06/20/12 12:45 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
gears 3:55 stall 2800
Nope, that's too much cam for those gears and converter
[Re: CUDA8U]
#1253919
06/20/12 01:24 AM
06/20/12 01:24 AM
Posts: 5,080 organ
maximum entropy
organ
too small in my 496. how big are you? big engine, go big. that cam in an 8:1 340 would be a turd on the street.
[Re: CUDA8U]
#1253921
06/20/12 08:16 AM
06/20/12 08:16 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
well thanks guys,I realize it's an open ended question with all my specs etc
gears 3:55 stall 2800 manual steering/brakes but may ad power steering 10-1 comp
i just stumbled upon this cam in a local ad and thought I'de ask
thanks again
No it's not a street cam, unless your idea is driving it to the track and racing it and second it will not work well w/ what you have. If i were you I'd look in the 480-490ish range and something around 220 @ .050
