I have a 383 in my duster. It has a mopar performance/direct connection ignition in it. When i set total timing to 36 degrees, I get a miss above 2000 rpm at light throttle. When the vacuum is disconnected no miss. It seems like there's too much timing, or the rotor/reluctor phasing isn't correct. I have heard about a modified reluctor that corrects phasing problems. OR, with the 36 degrees total I'm running, is it just impossible to run vacuum advance too? Maybe cut down on amount of vacuum advance, are there cannisters that have different amounts (in degrees) of advance? somebody has to know the REAL story.
