Re: Finally getting rid of the woodgrain
[Re: 19SuperBee70]
#1253798
06/19/12 11:59 AM
06/19/12 11:59 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I also think the black looks better. I actually prefer the earlier "striped" black ones but we can't use those because the earlier cars had the hazzard switch on the dash. I used the woodgrain because I wanted my car to be correct appearing but it would have saved $650.00 to just go black....the thought did occur to me FWIW, the PG classics black bezels don't have the tabs for the woodgrain cut out, so it would be really easy to omit the woodgrain using those plus you would get the chrome strip on the edges. Anyhow, looks good. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 19SuperBee70]
#1253799
06/19/12 07:37 PM
06/19/12 07:37 PM
Posts: 821 NW Ohio
6pkaar
NW Ohio
Sanded and added the mottled texture
How did you do the texture?
[Re: 6pkaar]
#1253800
06/19/12 08:49 PM
06/19/12 08:49 PM
Posts: 629 Michigan
dart1962_440
Yeah, more texture info please!
[Re: 19SuperBee70]
#1253804
06/20/12 09:32 AM
06/20/12 09:32 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I used a combo of a razor and a dremel diamond tip bit shown below. It was hard to do, it looks better than I thought it would. A few time I cut too deep and had to start over. Once I was satisfied I sprayed a coat of primer. Then i sprayed a coat of rustoleum flat black texture paint, this helped to blend everything together. then I applied a few coats of sem landau black.
ok so much for the tools.HOW did you do it,it looks awsome,how long did it take?
