Page 3 of 3 1 2 3
Re: W9 port developement continues [Re: bwhackd34] #1253422
06/25/12 06:10 PM
06/25/12 06:10 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Good Job Hope to see final Numbers On the BENCH and on the Track.
It just always amazes me that people forget what & where these heads came from and what they have done in the PAST and a Distant past at that.
410" Alcohol Sprint Cars (750-850hp)
NHRA ProStock Truck 358cui and 7.50/180mph 1/4 miles Turning 10,500rpms.
Nascar Cup and Busch Series 358cui.
I have a set of W9-RP (I know they are a Bit Different) but the shop that ported them claimed 400-425cfm depending on which bench they were on. Also told me I could probably get another 25cfm if I sent them to Reher-Morrison and let them run their W9-RP CNC Program on them.
I personally would like to see what the W9s are really capable of. Like a Few others I have a NIB set under my bed. LOL!
I only know of 3 small block heads that come even close to the W9's. SB2's, Mozez, and P7.
I wouldn't even consider the P5-Hemi in the running. How available is it and did they ever fix the Leaking Issues.
Re: W9 port developement continues [Re: bwhackd34] #1253423
06/25/12 06:18 PM
06/25/12 06:18 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
"and to the guy who asked about how much you moved the guides,, or how big of a valve,, he must not have read that earlier you said you didnt do any of that,, the head is mechanically as recieved from mopar.."
I did read the entire post and I personally don't see any way to get those kinds of numbers without moving/changing the "factory" paramteters. Rolling/angle milling helps but you need more than that. Next you will say it uses 3/8 stem valves... lol Just kidding, keep up the good work. It is nice to see a thread dedicated to hard core smallblock cylinder head developement.
Re: W9 port developement continues [Re: stevet340] #1253424
06/25/12 06:56 PM
06/25/12 06:56 PM
PA
bwhackd34 Offline OP
PA
Nope..no .375 stems.....and you are correct....rolling the head has very little impact on flow.....
Re: W9 port developement continues [Re: DakFink] #1253425
06/25/12 07:15 PM
06/25/12 07:15 PM
PA
PA
Thanks for your support...and thanks for supporting us all.....noticed you serve....thanks again!
Re: W9 port developement continues [Re: bwhackd34] #1253426
06/25/12 10:10 PM
06/25/12 10:10 PM
nc
moeflo Offline
moeflo  Offline
nc
It's good to see the critics and the criticized go about this without things getting personal.
It's so not Yellow and/or ST of you (and Jeff and Dennis) and I for one appreciate it.
I don't recall any SB inline-valve head for any brand matching your high lift numbers. I'm looking forward to your on-track verification of these. I've never done any W8 or W9's, but always "heard" the W8's were better for a "big" application. Do you think you have enough material in critical places to just digitize and CNC it? One usually has to allow just a bit of cushion due to core shift.
And just wondering, if not another secret, have you modified your port for a longer valve?
No matter, good to see civilized dialog going on instead of chest beating.
Re: W9 port developement continues [Re: moeflo] #1253427
06/26/12 12:10 AM
06/26/12 12:10 AM
Dillsburg PA
airflowdevelop Offline
Dillsburg PA
If my post was taken as being a critic... someone took it the wrong way. I am only stating that I would love to see the head on my bench to see what it does. If it goes 475 @ 60" of depression corrected the man hit a home run!
Re: W9 port developement continues [Re: moeflo] #1253428
06/26/12 06:25 AM
06/26/12 06:25 AM
PA
PA
really no sense in getting personal...if I was afraid of the comments then I shouldnt have publicly posted in the first place....
The port hasn't been alter for a longer valve...the issue with CNC'ing is one I will need to work out when I get to that point...I am well aware that there are some thin areas right now that could prove to be an issue....8's would be better as they have thicker castings and would be more forgiving...not necessarliy sure that making the port larger would be beneficial but that would also be an option with them....unfortunately I have a set of 9's so that is what I will be transferring the design to....one way or another...once I am satisfied with the results....
Re: W9 port developement continues [Re: airflowdevelop] #1253429
06/26/12 06:35 AM
06/26/12 06:35 AM
PA
PA
what type of bench are you using?...if it is a Superflow(or Superflow based design) there is no need to correct....a properly calibrated Superflow will provide the same results regardless of altitude, humidity, temp etc...they are basically self correcting. If you mean flow @28" mathematically corrected for 60" then the number should be nearer 660....450@60" mathematically corrects to 307@28"...I realize that the higher depression may/will cause conditions in the port that may/will change flow levels just wondering exactly what you meant?
Re: W9 port developement continues [Re: airflowdevelop] #1253430
06/26/12 10:30 AM
06/26/12 10:30 AM
nc
moeflo Offline
moeflo  Offline
nc
Dennis. I don't mean "critic" in a negative sense. If I reset the bar on flow in a well known specific casting, I'd expect some critics. I'd expect to eventually need proof, if not on the bench, on the ET slip. I'm just happy to see no one is throwing rocks this time.
Re: W9 port developement continues [Re: moeflo] #1253431
07/05/13 04:06 PM
07/05/13 04:06 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Any updates?
Re: W9 port developement continues [Re: rt66jim] #1253432
07/08/14 12:42 AM
07/08/14 12:42 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I am still interested in an update.
Re: W9 port developement continues [Re: rt66jim] #1253433
07/08/14 02:20 AM
07/08/14 02:20 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Not looking good on that update....
Re: W9 port developement continues [Re: SpareParts] #1253434
08/03/14 08:37 PM
08/03/14 08:37 PM
PA
PA
Sorry ...I just saw these most recent posts. I have not been playing with them for a while ...I am pretty satisfied with the port design as it was when this post was written. I recently bought a set of raw w8 castings and my plan was to see if the port would be easier to adapt to the 8's over the 9's. Once winter sets in I plan to dig them back out... as well as the untouched blue plug 5's I picked up and the 2's on the car right now......work schedule permitting.....thanks for you interest!
Page 3 of 3 1 2 3
