Best Hemi clutch #1253291
06/18/12 08:04 PM
06/18/12 08:04 PM
WI
ThunderLugs Offline OP
WI
I'm ready to upgrade the clutch in my Hemi Coronet. Brand or product advice? Don't have it apart yet. It has been a few years. Flywheel has 130 teeth. I'm thinking 10.5. I know it is not 11". Looking for recommendations.
Re: Best Hemi clutch [Re: ThunderLugs] #1253292
06/18/12 08:10 PM
06/18/12 08:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What year? Stock HP or not?
An original Hemi with a 130 tooth flywheel would have had the 10.95" clutch. I had a 10.95" Centerforce Dual-Friction behind my stock Hemi and loved it.
Re: Best Hemi clutch [Re: John_Kunkel] #1253293
06/18/12 08:22 PM
06/18/12 08:22 PM
WI
WI
The car is a 67 j code RT. These parts were hard to come by in the 70's. I bought the flywheel from a drag racer. It's a bit odd, even though, it's a 130 teeth it is less than 10.95. It's closer to 10.5. It's a bit of a freak unless race hemis 64 and 65 ran this size. Are you aware of any sizes other than the 10.95? Also the motor is not stock. Barnett Automotive in Georgia did it back in the 80's. There are only a few thousand miles on it. 11.5 to 1. 557 cam. VANKE intake modification. Also running a Ansen bellhousing and saver plate. No inspection cover so can't measure. May have to wait on the purchase until I take it apart.
Re: Best Hemi clutch [Re: ThunderLugs] #1253294
06/18/12 10:04 PM
06/18/12 10:04 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Call Tim Hyatt or E-mail him http://hyattracingservices.com/home.html
He can build you a 10.5 clutch that your HEMI wont burn up
Gus
64 Plymouth Savoy
Dana 60
Re: Best Hemi clutch [Re: ThunderLugs] #1253295
06/19/12 01:41 PM
06/19/12 01:41 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The 130 tooth flyweel will accomodate a 10.5 or a 10.95 pressure plate. They have the same bolt pattern.
Re: Best Hemi clutch [Re: GomangoCuda] #1253296
06/19/12 02:21 PM
06/19/12 02:21 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
McLeod makes some good clutches in the 10.95" for 130T wheel. I assume you have 18 spline? This clutch is also available for the 23.
http://brewersperformance.com/proddetail.asp?prod=MCP1018
or diaphragm plate.
http://brewersperformance.com/proddetail.asp?prod=MCDP1018
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Best Hemi clutch [Re: GomangoCuda] #1253297
06/20/12 10:49 AM
06/20/12 10:49 AM
WI
WI
Tank U For the Info!
Re: Best Hemi clutch [Re: 64dodge572] #1253298
06/20/12 09:49 PM
06/20/12 09:49 PM
WI
WI
Thanks! You Guys Rock!!
