synthetic versus conventional weight? #1253117
06/18/12 02:05 PM
06/18/12 02:05 PM
Alliance, Ohio
V
Valiant_Showoff Offline OP
V
Alliance, Ohio
I have always run Valvoline conventional 10W-40 (with zinc additive) in my street/strip small block, but switched to 10W-40 Valvoline synthetic for the first time and wondering my oil pressures are thru the roof.
Conventional was always at 40 lbs at idle and 60-70 lbs at speed. Now with the synthetic I'm at 60 lbs at idle and 70+ when cruising. Is this normal for synthetic oil?
Should I be running a thinner synthetic than what I'm used to? If so, what weight?
Re: synthetic versus conventional weight? [Re: Valiant_Showoff] #1253118
06/18/12 02:11 PM
06/18/12 02:11 PM
this is the first time I've heard of synthetic oil having more pressure than conventional oil
Re: synthetic versus conventional weight? [Re: Cab_Burge] #1253119
06/18/12 02:19 PM
06/18/12 02:19 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Usually drops a couple pounds.
Re: synthetic versus conventional weight? [Re: BobR] #1253120
06/18/12 02:31 PM
06/18/12 02:31 PM
canada
jp15 Offline
jp15  Offline
canada
did you use same brand oil filter on change over???
Had heard of some FRAM filters acting funky
Re: synthetic versus conventional weight? [Re: jp15] #1253121
06/18/12 06:49 PM
06/18/12 06:49 PM
Alliance, Ohio
V
V
Alliance, Ohio
Oil filters are the same. NAPA Gold.
Weird. So the pressure should have dropped?
Re: synthetic versus conventional weight? [Re: Valiant_Showoff] #1253122
06/18/12 09:24 PM
06/18/12 09:24 PM
IN
ahy Offline
ahy  Offline
IN
With real hot oil, the synthetic may hold a higher actual viscosity but it really does sound like you could run lighter oil... I bet 10W30 would work fine and put less load on the pump and drive. I'm happy with 20+ PSI at hot idle and 60 ish at speed.
