Will these leaf springs work? #125308
09/23/08 11:28 PM
09/23/08 11:28 PM
Brownsburg, IN. U.S.A.
speedjunkee Offline OP
I have a 78 Dodge Aspen, One of my leaf spring are broke and I have a set of springs from a 74 Cuda. I was just wondering if these might fit or what I would have to do to make them work and if it would be worth it.
Richard Dodrill
SpeedJunkee's Carbs and Performance
108 1/2 Grant St
Brownsburg, IN. 46112
317-292-3814
speedjunkeecarbs@comcast.net
Re: Will these leaf springs work? [Re: speedjunkee] #125309
09/24/08 07:21 AM
09/24/08 07:21 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
if you're just using one of the support leaves, I wouldn't see why not. If you need the main, you'd have to measure them up as far as length and end sizes.
1981 Dodge D150 360 auto
Re: Will these leaf springs work? [Re: speedjunkee] #125310
09/24/08 08:17 PM
09/24/08 08:17 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
F body and late 70s B body used an Oval front eye and bushing. The Cuda will be a standard round eye.
If you main leaf is broken, you cannot use the Ebody.
Re: Will these leaf springs work? [Re: sthemi] #125311
09/24/08 11:44 PM
09/24/08 11:44 PM
The main leaf is broke. It is broke where it mounts to the front.
Richard Dodrill
108 1/2 Grant St
317-292-3814
Re: Will these leaf springs work? [Re: speedjunkee] #125312
09/25/08 12:59 AM
09/25/08 12:59 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
That is the common place with those...
There aren't many left in the boneyard.
you could try car-parts.com
Or put an ad in the parts wanted section, I bet 5th av. springs would bolt in..
