Re: Holley Commander 950 EFI Questions............
[Re: oldsklharo]
#1253097
06/18/12 01:54 PM
06/18/12 01:54 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
To sum them up,from reports I've read - The TB isn't too bad, the ECU is the poor performer.
EDIT - Saw you said multi-port, so scratch the part about the TB, depending on teh vintage of the ECU it may still be a valid assessment.
[Re: Fury Fan]
#1253098
06/18/12 03:35 PM
06/18/12 03:35 PM
Posts: 287 Iowa, US
oldsklharo
Iowa, US
Thanks for the info...... the kit is from around 2006. Do you know if by then the ECU had been upgraded or the bugs worked out of it?
[Re: oldsklharo]
#1253100
06/19/12 10:32 AM
06/19/12 10:32 AM
Posts: 309 Hampden, Maine
Procommuter
super street
super street
Hampden, Maine
I have a C950 on my Cuda. It works fine but I did have to have an ECU replaced early on under warranty. I am constantly playing with the setting to make the drivablity better. Don't get me wrong compared to a carb it runs great, but each time I drive a late model car with standard shift and a V8 I start working to make the Cuda better. As with any EFI wire the power and ground dirrectly to the battery and connect the body, engine and ECU all together with ground wires. PM me if you have any specific questions.
Wes
73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
[Re: Procommuter]
#1253101
06/19/12 10:36 AM
06/19/12 10:36 AM
Posts: 287 Iowa, US
oldsklharo
Iowa, US
Just what the doctor ordered.....YGPM
