Re: Fired the BAE hemi this weekend
[Re: BobR]
#1253075
06/18/12 01:45 PM
06/18/12 01:45 PM
Triple Threat
Renton Washington
I know its been a long road getting this thing going again. Glad to hear its making noise, in a good way!!!
[Re: go green]
#1253079
06/18/12 02:21 PM
06/18/12 02:21 PM
Posts: 8,165 Left Coast
BobR
Left Coast
That's great news ,, I felt the ground shake way up here , thought it might be you guys
What you heard was the echo from the Green Monster.
[Re: cold85]
#1253080
06/18/12 02:22 PM
06/18/12 02:22 PM
BobR
Left Coast
Nice, the guys I use are building one now as well.
What efi are you using?
BS3 with Precision injectors.
[Re: Triple Threat]
#1253081
06/18/12 02:31 PM
06/18/12 02:31 PM
BobR
Left Coast
There were a few roadblocks, questions and logistical constraints with this update. All of the doubt was answered when it was running on all 8. We think that we'll be able to contend with anyone running a true Outlaw car. The new front end glass will be here on Friday so when That's done we will try to test somewhere. Hopefully in about 4 weeks.
[Re: BobR]
#1253082
06/19/12 03:56 PM
06/19/12 03:56 PM
Posts: 452 nc
cold85
nc
same here with a mag
[Re: BobR]
#1253084
06/19/12 09:04 PM
06/19/12 09:04 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Cant wait to hear how it scoots once dialed in!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: LA360]
#1253086
06/20/12 02:23 AM
06/20/12 02:23 AM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Cant wait to see it back out there mixing it up in Outlaw...
[Re: BobR]
#1253087
06/20/12 09:41 AM
06/20/12 09:41 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Looks terrific....cant wait to see the results on this deal. Good luck this year
RIP Monte Smith
[Re: sdaurity]
#1253089
06/20/12 04:27 PM
06/20/12 04:27 PM
BobR
Left Coast
Is that a 139 or a 136?
136.
[Re: Al_Alguire]
#1253090
06/20/12 04:32 PM
06/20/12 04:32 PM
BobR
Left Coast
There are a couple who would rather we had stayed retired. Everyone's best guess has us well north of 3000 HP. At 2650 pounds this thing should really move.
[Re: cudacustoms1]
#1253093
06/21/12 01:10 PM
06/21/12 01:10 PM
BobR
Left Coast
Looks great! I don't know how hp #'s compare from turbo to roots supercharger but we dynoed my 540 BAE fathead fully moded k-11 superman @50 over. Best #'s were 2153hp.It was to lean for what we need.So we had to add fuel. It was living well in the 1800hp range on the dyno. I heard all kinds of numbers before we ran it but thats what it made.I would be very interested to here some real world dynoed turbo motor numbers.Good luck with your combo!My motor was 39lbs of boost. What version of brads heads are you running?
We are running BA-8 alcohol heads. Our SBF/135 procharged deal went 6.61/213 at 2750 pounds and 430 cubes on Q16. I think that figures out to something over 2000 HP. The 136 P/charger is supposed to be a lot better than the 135. We have 70 more cubes, heads that flow well over 100 CFM more and we're using M5. We'll see. Yeah HP numbers are often exaggerated. If we make close to 3000 I'll be real happy.
