Re: 4 speed codes breakdown
[Re: gtx6970]
#125303
09/24/08 03:53 PM
09/24/08 03:53 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
PP8353986 023 2-498327
I'll take a guess...
Is the first five a three, perhaps, or no?
3986, if it's the 10k calendar date would = 6/26/1972, and 023 = 23rd trans built that day
498327 should be the sequence number, but that seems high- 498,327 vehicles produced in '72? If the above 10k date is correct, it would be very late into the '72 model year, so it should be a high sequence number, but I have no clue how high they went in '72. The "2" before the "-" = '72. Can you read what the plant code number is, or is there just a dash in that location?
Wasn't '72 the year of the UAW strike, or was that at GM only?
[Re: gtx6970]
#125304
09/24/08 04:35 PM
09/24/08 04:35 PM
Posts: 17,521 Las Vegas, NV
6bblgt
Las Vegas, NV
I'd "assume" if 2 lines of info:
2B498327 PP833 3986 023
Hamtramck assembly is the only plant with 400000+ for the VIN sequence so the "B" would make sense for the 1972 model year. A & E-bodies were built there, long or short tail shaft? 398327th vehicle at that plant, that model year.
