Who runs a PTC converter with their smallblock 727?
#1252592
06/17/12 01:21 PM
06/17/12 01:21 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I have a SB 727, and I I need to purchase a flexplate. Trouble is, I don't have the converter yet, and I don't know what bolts size is used, and the bolt circle diameter. I'm going to buy a PTC converter next week, and I wanted to find out ASAP what size converter bolts you use, 5/16 or 7/16? Also, there are two bolt circle sizes, 10" and 11.1". Is there a set standard for SB 727's? Lastly, can SB and BB 727 converters interchange?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Who runs a PTC converter with their smallblock 727?
[Re: mopartony]
#1252597
06/17/12 01:46 PM
06/17/12 01:46 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
I've had small blocks with both size flexplates. Depends on the stall and size of the converter itself. I just ordered a PTC converter for my BB and it cost an additional $20 for the 7/16 bolts. Almost all standard flexplates are the small size hole. All 727 converters are the same and will interchange, with the exception of the balance weights for a 360 or 400.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1252598
06/17/12 02:28 PM
06/17/12 02:28 PM
Posts: 4,421 in a chair
mopartony
in a chair
Dave, Not sure if you knew Meziere made flexplates but I am going with one of thier's on my new build. Needs to have custom hole pattern for the crank and 6 bolts for the NCR converter but I was told in the $500-550 range for one. Here is link http://www.meziere.com/displaycategory.aspx?id=111,112,125 Like you said, buy once, cry once.... I like that. Going to have to use it when asked why parts are so expensive and buying the cheap ones...
[Re: mopartony]
#1252599
06/17/12 04:30 PM
06/17/12 04:30 PM
Posts: 169 Finland, Europe
Ck[FIN]
Finland, Europe
I have 2 PTC converters for SB 727. They are 7" and 8". Both with 7/16 bolts. Flexplate is B&M SFI-approved and has 3 different bolt patterns, 2 for smaller and 1 for 7/16 bolts.
-1965 Valiant 9.03s 358cu.in R5P7-
