how to determine sping rate for 4 link, coil over #1252517
06/17/12 11:05 AM
06/17/12 11:05 AM
CheddarHead till October
weedlayer Offline OP
chart? formula? pull straws??
Re: how to determine sping rate for 4 link, coil over [Re: weedlayer] #1252518
06/17/12 11:16 AM
06/17/12 11:16 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
from what I was told at QA1...put the rear on scales...then look it up on charts...Strange has one also..
http://www.qa1.net/tech/drag-street-faqs.php
Re: how to determine sping rate for 4 link, coil over [Re: weedlayer] #1252519
06/17/12 11:25 AM
06/17/12 11:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You have to know the rear weight(race weight) then
subtract the weight of the diff then bases on that
weight you can determine the spring rate... length
is determined by the shock used
Re: how to determine sping rate for 4 link, coil over [Re: MR_P_BODY] #1252520
06/17/12 11:32 AM
06/17/12 11:32 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Monte Smith once told me to select the lightest coil over spring that will hold the car up.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: how to determine sping rate for 4 link, coil over [Re: DusterDave] #1252521
06/17/12 11:51 AM
06/17/12 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats true... just need to hold the body up
Re: how to determine sping rate for 4 link, coil over [Re: MR_P_BODY] #1252522
06/17/12 12:11 PM
06/17/12 12:11 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Yes lightest spring to hold the car up at the shocks install height without using more than an inch of preload in the spring. That is what I use and we used on the pro-mod/ADRL cars I have been around.
