340 oil filter adapter #1252395
06/17/12 12:02 AM
06/17/12 12:02 AM
central illinois
65dodgebob Offline OP
central illinois
is there a foolproof way to seal this thing up? had it apart to fix a leak,used a new gasket, but leaks like a sieve now! anyone have a torque spec for the large bolt that holds it on? thanks!
Re: 340 oil filter adapter [Re: 65dodgebob] #1252396
06/17/12 12:16 AM
06/17/12 12:16 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Put a regular filter mount on it and use a short filter..
I am truckless..
Re: 340 oil filter adapter [Re: 340SHORTY] #1252397
06/17/12 12:52 AM
06/17/12 12:52 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
Same here. I got rid of the darn thing. If you insist on using it, use the mopar gasket kit. I could never get enough space to get a torque wrench on it so I tightened it as tight as I could get it within reason. I have heard of some people saying the bolt is too long and they had to shorten it because it was bottoming out but I never ran into that myself. Remember there are 3 gaskets. One on the block and two on the bolt.
Re: 340 oil filter adapter [Re: mopars4ever] #1252398
06/17/12 01:29 AM
06/17/12 01:29 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Some kits have two gaskets, the inner 'two' are connected with spokes like a wagon wheel.
Re: 340 oil filter adapter [Re: Alaskan_TA] #1252399
06/17/12 02:51 AM
06/17/12 02:51 AM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
Torque it to 50. Buy the mopar kit and use the 2 small ones from kit and buy the felpro one for the large gasket from local parts store. The large felpro one is a little thicker and is only a couple of bucks.
Re: 340 oil filter adapter [Re: 1970sixpak] #1252400
06/17/12 10:08 PM
06/17/12 10:08 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
The problem is when you use that extra thick inner gasket. It bottoms out way before the outer gasket and you think you got it tight but the outer gasket still does not have enough pressure on it. I would put some putty on the inner mating surfaces and then temporarily install it and then remove it and see how thick the putty is. That will tell you how thick the inner gasket should be.
Re: 340 oil filter adapter [Re: 340SHORTY] #1252401
06/17/12 11:07 PM
06/17/12 11:07 PM
Third rock from the sun.
busboy Offline
busboy  Offline
What the heck does a "regular filter mount" look like? I've never seen one! My 90 degree adapter just puked out half the oil on the garage floor. Made up the big gasket, it's holding fine, now the smaller one at the head of the bolt is leaking like a sieve
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: 340 oil filter adapter [Re: Steve340] #1252402
06/17/12 11:26 PM
06/17/12 11:26 PM
Excellent idea!. Some of those inner gaskets are very thick
Re: 340 oil filter adapter [Re: 65dodgebob] #1252403
06/18/12 03:31 PM
06/18/12 03:31 PM
fiddlerfingers Offline
I bet your trying to use a Mopar Performance aluminum adapter huh? They suck!!! There milling is aweful and causes them to leak. I tried one and couldnt get it to work so I bought a cast iron one off of ebay and it sealed without a hitch. The guy at my local dodge parts department told me everyone he has sold gets brought back...
Re: 340 oil filter adapter [Re: 1970sixpak] #1252404
06/19/12 12:28 AM
06/19/12 12:28 AM
busboy Offline
busboy  Offline
Sixpack, don't have a part number for that felpro gasket do you? Local parts place couldn't come up with one.
Re: 340 oil filter adapter [Re: busboy] #1252405
06/19/12 03:17 AM
06/19/12 03:17 AM
md
md
a base plate and the threaded adapter. http://t1.gstatic.com/images?q=tbn:ANd9GcQoFsdUS3M-gSsQGBcnUcYx1FEbSOGIOfvPbOEdmoS9bVyJxCKJlw
Re: 340 oil filter adapter [Re: busboy] #1252406
06/21/12 07:50 PM
06/21/12 07:50 PM
busboy Offline
busboy  Offline
Found one! FelPro #70522, replaces #3671314, for the adapter to block gasket. It's a bit thicker than the Mopar factory one.
Re: 340 oil filter adapter [Re: Alaskan_TA] #1252407
10/04/12 07:18 PM
10/04/12 07:18 PM
Illinois
mrb Offline
mrb  Offline
Illinois
I saw one of your old posts responses regarding a 340 engine, 90 degree oil filter adapter gasket set. You came up with part # 70522 felpro. Thats just one. How could I find the (oil pressure relief) bolt gaskets? 1 is copper and other cork? NAPA can't locate the other two.
Hope you can help.
71 Chally convert.
70 'Cuda 440-6
Former cars: 68 formula S 383 4 speed convertible
70 T/A challenger SIX PAK Mr. Norm's
( yellow one in the six pack magazine pg84)
68 formula S 340 auto.
70 grand coupe convertible 318
looking for broadcast sheet BS23V0B146604
