Page 2 of 3 1 2 3
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252253
06/17/12 10:15 AM
06/17/12 10:15 AM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Take your time and look at everthing closely,My times started slipping I thought of everthing mentioned here, I just put it off as a crappy track prep, Yesterday I broke my motor, Rod thru the pan, water/oil mix your know what that means, Trust that little voice in your head if it isnt right don't run it.
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252254
06/17/12 10:17 AM
06/17/12 10:17 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Time for a leak-down test.
If you like drag racing, support your local track.
Re: Ok so my car is 5 tenths slow [Re: CHAPPER] #1252255
06/17/12 10:20 AM
06/17/12 10:20 AM
ill
dennismopar73 Offline
ill
i AGREE!
Re: Ok so my car is 5 tenths slow [Re: Chris'sBarracuda] #1252256
06/17/12 10:22 AM
06/17/12 10:22 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Sounds like someone put a two barrel carb and a set of mufflers on it. 3 carbs-2 MSD boxs-2 fuel pumps-3 sets of plugs-cap&rotor. all been change. check valve lash 5 times ! springs look ok not that old-Just took the front of the motor apart everything on the timing chain looks great. also change it from e-85 to gas no change. timing is rock solid. 18-34 .
nothing in the oil filter. compression test good 100-170 . will not rev up..not crisp and clean. What else to check- ideas..split them out !
What? 100psi is barely enough to fire a cylinder..
Chris..
I am sure that was a misprint on the 100#. is the pick-up leads going to the MSD box in phase? I know if they are reversed it will usually mess with the timing.
Re: Ok so my car is 5 tenths slow [Re: dartman366] #1252257
06/17/12 10:24 AM
06/17/12 10:24 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Chris..
Re: Ok so my car is 5 tenths slow [Re: CHAPPER] #1252258
06/17/12 10:40 AM
06/17/12 10:40 AM
tboomer Offline
tboomer  Offline
Vern...Didn't you just change the coil a while back?
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252259
06/17/12 10:53 AM
06/17/12 10:53 AM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
I also agree with a leakdown...fuel volume seems low according to your post. I use this as a diagnostic tool- 8 sec. car...one gal. in 15 seconds;9 second car in 20 seconds;10 second car in 25 seconds;11 second car in 30 seconds;12 second car in 35 seconds. Hope you find your problem
Re: Ok so my car is 5 tenths slow [Re: MoparPitBull] #1252260
06/17/12 11:35 AM
06/17/12 11:35 AM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
had 3 coil on it now.. will do a leak down here today.. compression 120 over 170 .. that is 1 cy. has max 165-170 on all 8. I know some here do not understand 2 numbers on a compression test. you have your first hit then you second hit. Thank you all very much for the repleys
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252261
06/17/12 11:42 AM
06/17/12 11:42 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
"120 over 170",,,,are you taking it's blood pressure..??
Re: Ok so my car is 5 tenths slow [Re: MoparPitBull] #1252262
06/17/12 11:44 AM
06/17/12 11:44 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Verify your timing mark and lock out your distributor .I had a harmonic balancer that I could could grab and twist the outer case on ,,I think it was a TCI rattler .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Ok so my car is 5 tenths slow [Re: go green] #1252263
06/17/12 11:53 AM
06/17/12 11:53 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I have check balancer- drist-shaft-gear on pump shaft-timing chain-gears everything is good there.
Re: Ok so my car is 5 tenths slow [Re: CHAPPER] #1252264
06/17/12 12:33 PM
06/17/12 12:33 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
better check for a pulse.
Re: Ok so my car is 5 tenths slow [Re: dartman366] #1252265
06/17/12 02:55 PM
06/17/12 02:55 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Try another known good battery and make a pass
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Ok so my car is 5 tenths slow [Re: B3422W5] #1252266
06/17/12 03:09 PM
06/17/12 03:09 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Bad plug wire !!Test open
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252267
06/17/12 03:11 PM
06/17/12 03:11 PM
tboomer Offline
tboomer  Offline
Good find,Vern! I was hoping that is something simple!
Re: Ok so my car is 5 tenths slow [Re: tboomer] #1252268
06/17/12 03:39 PM
06/17/12 03:39 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Cut the boot off the wire and this is what I found.
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252269
06/17/12 03:50 PM
06/17/12 03:50 PM
tboomer Offline
tboomer  Offline
Ouch!! I pulled one of my Firecores apart by accident..So I cant't fire mine up till I get a replacement or repair this one. I think Rick may be on vacation?
Re: Ok so my car is 5 tenths slow [Re: tboomer] #1252270
06/17/12 03:55 PM
06/17/12 03:55 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
hmmmmm, I wonder how many times that was talked about, supposed that was the popping out the exhaust?
Re: Ok so my car is 5 tenths slow [Re: dartman366] #1252271
06/17/12 03:59 PM
06/17/12 03:59 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Yep ..replaced everything on the car but them. and yes you told me to test them ..O well..live and learn..Always come down to something dumb. must of been fire some times that why we heard that and then it quit all together. I sure thought it would of sounded and run diff than that.??
Re: Ok so my car is 5 tenths slow [Re: VernMotor] #1252272
06/17/12 05:21 PM
06/17/12 05:21 PM
Johnstown
69dart Online content
69dart  Online Content
Johnstown
Holy Crap - All that and it ended up being a plug wire. At least you figured it out!
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Page 2 of 3 1 2 3
