After much time, hard work, and deniro I have finally acheived my 10 second crusade with my street driven Barracuda, thanks to many of you guys on countless posts I have started and you have helped. I drove my 67' Barracuda to the track 10 miles away streeet legal, except for slicks and layed down a 10.59 at 128 mph with a sluggish 1.630 60'. This was accomplished after adding the small shot of nitrous to my set-up. The tune suggestion of 55N/47F, 30* timing, 5-7 lbs of fuel pressure, and AR3934 autolite plugs did the trick. I then jumped in my new 10 second car and drove home with a big grin......I had ran a best of 11 teens, not bad, but not 10 seconds.
