MSD Atomic EFI? #1252119
06/16/12 02:48 PM
06/16/12 02:48 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Has anyone tried or have experience with the MSD Atomic EFI? Any reviews? Thinking of running one over a quickfuel carb on a street 470. Thanks in advance
Re: MSD Atomic EFI? [Re: 70VcodeCoronetRT] #1252120
06/16/12 03:42 PM
06/16/12 03:42 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Just installed one on a friends car. Scamp with a 318 with eddy heads & decent cam. works fine.
There was an issue at first, it started & ran but obviously wasn't right, would even die after a while. Thought t was the handheld at first but another friend local had one & same results so at that point we thought Power Module & when called they said they had a bad rum of them. Still getting some replaced & short of stock right at the moment. We got the one the friend that loaned us the hand held & re-programmed it for the 318 setup & just hit the key & it fired right up & is fine now, When the replacement comes in he'll just give it to the other guy...He blew the motor in his car! (Ford)
Not hard to install & the guy we talked to there ( victor ) was really good.
Butch
