70 Challenger Convertible Spare ** Need Help #1251968
06/16/12 10:13 AM
06/16/12 10:13 AM
FLPlum Offline OP
FLPlum  Offline OP
Hello fellow Chyrsler enthusiasts.
If someone has an original 70 Dodge Challenger convertible with the collapsible spare, I have a question.
I have all the hardware for the trunk area , but it does not look like I have any attachment for the spare to the floor. What does the floor area look like for the attachment.
Part of my floor area was replaced.
If any one could send me a close up photo of the center floor area, that would be Great.
Thank You!
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251969
06/16/12 10:42 AM
06/16/12 10:42 AM
From what I remember, there was a raised piece of metal almost like a I beam or something like that which the threaded rod attached to. Unfortunately, the chally vert is in my parents garage about 40 minutes away from me. I can try and get a pic the next time im over there though.
Re: 70 Challenger Convertible Spare ** Need Help [Re: ] #1251970
06/16/12 10:52 AM
06/16/12 10:52 AM
FLPlum Offline OP
FLPlum  Offline OP
Thanks! I have a feeling I may have to add that piece.
That's why a picture would be great. Waiting on a photo, so I can proceed, so when and if I would greatly appreciate it!
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251971
06/16/12 10:56 AM
06/16/12 10:56 AM
MD
floyd Offline
floyd  Offline
MD
Re: 70 Challenger Convertible Spare ** Need Help [Re: floyd] #1251972
06/16/12 11:02 AM
06/16/12 11:02 AM
FLPlum Offline OP
FLPlum  Offline OP
Thank You Very Much,
Looks like it may be a little more difficult than I thought.
This thread should work, but if any one has closer pic, thanks.
This forum is Great!
Mike
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251973
06/16/12 11:10 AM
06/16/12 11:10 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
if you don't have everything in that picture...you are out of luck...the i beam part is not available re pro but i guess used is the way to go...
Re: 70 Challenger Convertible Spare ** Need Help [Re: AARCONV] #1251974
06/16/12 11:12 AM
06/16/12 11:12 AM
maybe I am wrong but didn't the hard tops use the same mounting bracket as the convertibles? Just that the convertibles used the different hole.
Re: 70 Challenger Convertible Spare ** Need Help [Re: ] #1251975
06/16/12 11:44 AM
06/16/12 11:44 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Nope, vert is different, it doesn't have the rise built into it, it stays on the lower floor area.... But FWIW I made mine.... I cut up a couple brackets out of parts cars to get the section where the actual bolt goes & I made the section that connects them.. A little welding, a little grinding & there ya go...
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251976
06/16/12 12:38 PM
06/16/12 12:38 PM
FLPlum Offline OP
FLPlum  Offline OP
Hello,
I may be getting closer to the solution.
Just ran across several vendors offering the convertible weld-in bracket.
521 restorations Ft Collions CO
Mopar Metal Vancouver WA
Aut Metal Direct GA
They are all closed on Sat., but anyone here verify these suppliers?
Thanks Again !!
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251977
06/16/12 12:44 PM
06/16/12 12:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
AMD is a board supporter & actually is the manufacturer... Didn't know they were making that part.... Won't help me, I made mine 18 years ago....
Confirmed, it's available... Lucky you!!
https://www.autometaldirect.com/store/pr...ld-Down-Bracket
Re: 70 Challenger Convertible Spare ** Need Help [Re: floyd] #1251978
06/19/12 03:44 PM
06/19/12 03:44 PM
FLPlum Offline OP
FLPlum  Offline OP
Thank You for the link.
A couple of good pictures there. I have located the bracket through AMD. Does anyone have a closer photo of the attachment method. It looks like there are tack welds in one of the photos. Another photo looks like seam sealer was used.
Just want to make it right, if I'm going to do it!
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251979
06/19/12 03:46 PM
06/19/12 03:46 PM
FLPlum Offline OP
FLPlum  Offline OP
Any pictures of an original trunk floor spare bracket, showing the attachment to trunk??
Thanks in advance!
Mike Fields
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251980
06/19/12 10:34 PM
06/19/12 10:34 PM
Krum TX
hemibird Offline
hemibird  Offline
Krum TX
Hope this helps.
Thanks in advance!
Mike Fields
Re: 70 Challenger Convertible Spare ** Need Help [Re: hemibird] #1251981
06/19/12 10:36 PM
06/19/12 10:36 PM
Krum TX
hemibird Offline
hemibird  Offline
Krum TX
Another
Hope this helps.
Thanks in advance!
Mike Fields
Re: 70 Challenger Convertible Spare ** Need Help [Re: hemibird] #1251982
06/19/12 10:39 PM
06/19/12 10:39 PM
california
Mr D21 Offline
Mr D21  Offline
california
hardtop - big difference...
Re: 70 Challenger Convertible Spare ** Need Help [Re: hemibird] #1251983
06/20/12 02:46 PM
06/20/12 02:46 PM
FLPlum Offline OP
FLPlum  Offline OP
Thank You for the pictures. The light is kind of dark. How far from the edge of bracket to the crease in floor under convertible well? Looks like about 1/2 inch or so.
Also,
It is hard to see, but is the piece tack welded in several spots?
How many spots? Is there any look of original seam sealer or just welded on?
Sorry for the questions, But I just want to get it correct looking?
Mike
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251984
06/21/12 11:32 PM
06/21/12 11:32 PM
Krum TX
hemibird Offline
hemibird  Offline
Krum TX
Also,
Mike
I will look tomorrow. It originally would have been spot welded in.
Re: 70 Challenger Convertible Spare ** Need Help [Re: hemibird] #1251985
06/22/12 07:06 AM
06/22/12 07:06 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Does this help?
Re: 70 Challenger Convertible Spare ** Need Help [Re: larry4406] #1251986
06/24/12 10:10 AM
06/24/12 10:10 AM
FLPlum Offline OP
FLPlum  Offline OP
Thank You Larry 4406,
Yes this does help, as it shows every part for the trunk area. I did not know about the " N " "anti rattler jack stowage.
Also, I notice there are two different ways of stowing the bumper hook. One has it on top, and the other has it under the tire.
Still wondering how the trunk bracket was welded on at bottom, and just how it it sits (location). I think the front tip sits about an inch from the bend where the trunk floor rises up under the top well.
Thank you very much for the diagram, this is very useful.
Mike
Re: 70 Challenger Convertible Spare ** Need Help [Re: FLPlum] #1251987
06/24/12 02:15 PM
06/24/12 02:15 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
The convertible spare tire bracket is not usually spot welded - it is tack welded in place from the topside with a blob of weld every 1-1.5" or so.
At least for 1970
This is based on having a number of '70s, including a bracket that I removed along with part of the floorpan from a '70 'Cuda 340 convertible that was crashed/written off in 1973....
