10.5 or bigger? #1251803
06/15/12 10:45 PM
06/15/12 10:45 PM
USA
DAK512 Offline OP
DAK512  Offline OP
USA
If you were going to build a new car,would it be a 10.5 tire or a big tire car?
Re: 10.5 or bigger? [Re: DAK512] #1251804
06/15/12 11:02 PM
06/15/12 11:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All depends on what your doing with the car... if
its a bracket car... go big but if you plan on other
things with it... set it up for both sizes
Re: 10.5 or bigger? [Re: DAK512] #1251805
06/17/12 03:56 PM
06/17/12 03:56 PM
NC
440Jim Offline
440Jim  Offline
NC
There is no way I would limit a car build to a 10.5 tire, unless:
1) The class requires it (and you could build it bigger and still run the 10.5)
2) The car will be a moderate power combo, say 11.99-slower.
