Re: Intake Manifold
[Re: jeebis44]
#1251640
06/15/12 10:48 PM
06/15/12 10:48 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
How about molding it out of space-age plastic. Then it will be better than wood and won't be bothered by your leaky carburetor.
68 Roadrunner. 383 4-spd. Beat up.
Re: Intake Manifold
[Re: jeebis44]
#1251645
06/16/12 01:59 AM
06/16/12 01:59 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Id be forced to drink also if I had a Poly 318..
I am truckless..
Re: Intake Manifold
[Re: jeebis44]
#1251646
06/16/12 11:15 AM
06/16/12 11:15 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
OK - question remains... Factory isn't going to remake them, aftermarket refuses to support them, how do we cheaply and accurately reproduce them?
You can't and most wouldn't want to.
Re: Intake Manifold
[Re: 62maxwgn]
#1251647
06/18/12 01:34 PM
06/18/12 01:34 PM
dogdays
I am one of the lucky ones, I have a Weiand 7503 that I bought before they went out of production. But the issue is real.
Edelbrock makes their prototype intakes out of fiberglass. They actually dyno at more power because they don't conduct heat as well.
I have been dreaming about a ceramic intake that would run cool. I emailed Edelbrock about that several years ago and got the reply, we don't need to we have a foundry.
I'd like to have a 351W ford intake to compare port sizes and locations.
Or make up a set of spacers that'd allow the use of a 302 ford intake. Just think, MPFI on a Poly!
Of course you could also just weld one up.
I cannot understand why Holley can't run a batch of 7503s, used ones are tickling $500 on the 'bay.
I called Hot Hemi Heads a year ago and suggested they do a Poly intake. Their dual plane intakes for Hemi look really good.
R.
Re: Intake Manifold
[Re: jeebis44]
#1251652
06/18/12 02:47 PM
06/18/12 02:47 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
I won't accept the "you can't do it" attitude. Making a cast of the outside of the manifold would be relatively easy, but how do you get the inside passages?
You fill the intake with a liquid that will solidfy and then you destroy the intake to get the insides out.
It would be cheaper to buy one off ebay ...
