shifting question #1251224
06/14/12 09:26 PM
06/14/12 09:26 PM
Streetsboro ,Ohio
72duster318 Offline OP
Streetsboro ,Ohio
Ok, changed from the standard 2.73? 7" rear in my Duster to a 3.23 suregrip 8.75 rear, now the shifting in the 904 tranny is way off. Shifts fine if you do it manually. Is this something easily fixed or will it require the trans to be pulled? Thanks for any input.
If you didn't build it yourself, it's not really yours - Tim "the toolman" Taylor
Re: shifting question [Re: 72duster318] #1251225
06/14/12 09:34 PM
06/14/12 09:34 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
More than likely the shifting is just fine. Your speedo for one thing is not accurate unless you changed the gear so that will make it look like it is worse than it is. The gear ratio of the rear end will also change the speed shift ratio because of driveshaft RPM change.
