Need help B-body convertible rear side glass mechanism #1251214
06/14/12 09:25 PM
06/14/12 09:25 PM
near Port Huron, MI
Paul Offline OP
Paul  Offline OP
near Port Huron, MI
The passenger side rear window in my 1969 Coronet convertible has never worked properly as long as I have had the car. This caused the glass to work loose and eventually cause the stainless trim piece on the front edge of the window to crack and break off.
I scored another window frame at the Nats a year or two ago for it. Back in March when we had the warm weather I decided that it was time to fix it.
After a long fight it finally came out. Then the cold weather returned and the honey-do list took precedence over fixing the car.
Now, nearly 3 months later, I cannot recall how it all fit together.
I am in need of a good factory engineering drawing of the window and track assembly and/or some realy good detailed photos.
I also found what I believe to be the cause of the original problem, one of the rollers was broken and was lying in the bottom of the quarter panel. It's absence allowed the window to tilt to far forward as it was rolled up and down eventually breaking off the stainless trim.
Anyone know of a good source for the roller?
I have most of the pieces but cannot find the stud and the spring metal piece that appears to keep roller tension on the track.
This is my best guess at how it should all fit together. Am I on the right path?
Re: Need help B-body convertible rear side glass mechanism [Re: Paul] #1251215
06/14/12 10:40 PM
06/14/12 10:40 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Have not worked on one myself but here is the info from the service manual. Hope this helps.
Re: Need help B-body convertible rear side glass mechanism [Re: moparfan53] #1251216
06/14/12 11:02 PM
06/14/12 11:02 PM
near Port Huron, MI
Paul Offline OP
Paul  Offline OP
near Port Huron, MI
Thanks, it's definately better than what I have now.
Re: Need help B-body convertible rear side glass mechanism [Re: Paul] #1251217
06/14/12 11:24 PM
06/14/12 11:24 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Your welcome.
When I first posted the pic I was puzzled why it was smaller than the original. I found out that photobucket has default maximum size settings for uploading. I changed it so the pic is larger now, easier for reading and/or printing. So thanks to your question, I learned something new today.
Re: Need help B-body convertible rear side glass mechanism [Re: Paul] #1251218
06/14/12 11:41 PM
06/14/12 11:41 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
FWIW, here is the parts book view.
Re: Need help B-body convertible rear side glass mechanism [Re: moparfan53] #1251219
06/15/12 10:39 AM
06/15/12 10:39 AM
near Port Huron, MI
Paul Offline OP
Paul  Offline OP
near Port Huron, MI
Thanks! That just might do the trick.
Now I need find another roller to replace the broken one.
Re: Need help B-body convertible rear side glass mechanism [Re: Paul] #1251220
06/15/12 11:21 AM
06/15/12 11:21 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Good luck, no repops only originals and most of them are broken or loose and worn. DAMHIK
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Need help B-body convertible rear side glass mechanism [Re: MOPARMIKE69] #1251221
06/15/12 07:31 PM
06/15/12 07:31 PM
near Port Huron, MI
Paul Offline OP
Paul  Offline OP
near Port Huron, MI
That's what I was afraid of.
I have most of the pieces, looks like I need to make friends with a machinist to fabricate the pin and spring metal part.
Re: Need help B-body convertible rear side glass mechanism [Re: Paul] #1251222
06/15/12 08:55 PM
06/15/12 08:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The same part was used in a number of applications including C bodies...
Re: Need help B-body convertible rear side glass mechanism [Re: 1_WILD_RT] #1251223
06/17/12 10:05 PM
06/17/12 10:05 PM
near Port Huron, MI
Paul Offline OP
Paul  Offline OP
near Port Huron, MI
Any idea of which years I should be looking at?
