Why would an intake valve break? w/pics now #1250612
06/13/12 11:05 PM
06/13/12 11:05 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
My #6 intake valve is now part of my #6 piston. I haven't torn it completely down yet so I don't know where on the stem it broke. but what would cause this? Iron head hemi, stainless valves, correct springs, .628 cam, stock rockers, shift at 6200, through the traps at 6900.
Chris from New Jersey
Re: Why would an intake valve break? [Re: fig426] #1250613
06/13/12 11:09 PM
06/13/12 11:09 PM
Delray beach, Florida
P
Performance Only Offline
P
it's hard to say.
bad valve
detonation
valve/piston contact
non concentric seat
just for starters.
machine shop owner and engine builder
Re: Why would an intake valve break? [Re: Performance Only] #1250614
06/13/12 11:13 PM
06/13/12 11:13 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
it's hard to say.
bad valve
detonation
non concentric seat
just for starters.
the only other things I can think of would be
a tight guide
bad seat
What year heads are you running ? there was just a post with the seats falling out recently.
Re: Why would an intake valve break? [Re: DJVCuda] #1250615
06/13/12 11:24 PM
06/13/12 11:24 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Original '70 heads. I have (now had) about 60 passes on the engine. It just happened tonight (I think). I pulled it in the trailer perfectly fine Sunday. Today I fired it up to pull it out and clackity clackity. I'll tear it down tomorrow, but it's bothering me now to know what happened... Detonation maybe but I'd be surprised. 34 degrees advance on 93 octane pump with a splash of 110 leaded. 10:1 cr.
Re: Why would an intake valve break? [Re: DJVCuda] #1250616
06/13/12 11:26 PM
06/13/12 11:26 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Hey Dan,
You left off putting in 8000 RPM chip because of misinterpreting valve float as early rev limiter set in and then missing shift.
Not that I would know anything about that........
Best, Dave
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Why would an intake valve break? [Re: fig426] #1250617
06/13/12 11:30 PM
06/13/12 11:30 PM
Southington Ct.
turbobitt Online content
turbobitt  Online Content
Southington Ct.
Uncontroled seating veolcity otherwise known as valve float. Spring may have gone away.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Why would an intake valve break? [Re: fig426] #1250618
06/13/12 11:41 PM
06/13/12 11:41 PM
Az
Crizila Offline
Crizila  Offline
Az
You're lucky it didn't happen at RPM. Should be able to fix it in a few days so I can continue to monitor the caltrac thread
Fastest 300
Re: Why would an intake valve break? [Re: Crizila] #1250619
06/14/12 12:43 AM
06/14/12 12:43 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
keeper failure..retainer failure
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Why would an intake valve break? [Re: fig426] #1250620
06/14/12 01:02 AM
06/14/12 01:02 AM
New York
polyspheric Offline
polyspheric  Offline
New York
More than half of the broken valves (in my limited experience) were because the guide was replaced after the seat was cut.
Next on the list: valve bent "just a tiny bit", and was straightened.
Boffin Emeritus
Re: Why would an intake valve break? [Re: polyspheric] #1250621
06/14/12 02:13 AM
06/14/12 02:13 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
At the top of the list is non-concentric valve seats,Do research on which equiptment is the most accurate and who is the best craftsman not who is cheapest.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Why would an intake valve break? [Re: BIGSPEED] #1250622
06/14/12 05:10 AM
06/14/12 05:10 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Valve seized to guide. This just happaned to me on rhs iron heads.
Stainless valves with iron guides is not optimal
Re: Why would an intake valve break? [Re: sshemi] #1250623
06/14/12 12:05 PM
06/14/12 12:05 PM
organ
maximum entropy Offline
organ
thermal shock? not likely on an intake. just putting it out there.
Re: Why would an intake valve break? [Re: maximum entropy] #1250624
06/15/12 12:22 AM
06/15/12 12:22 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Ouch
Re: Why would an intake valve break? [Re: fig426] #1250625
06/15/12 12:23 AM
06/15/12 12:23 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Salt on the wound
Re: Why would an intake valve break? [Re: fig426] #1250626
06/15/12 12:58 AM
06/15/12 12:58 AM
Ouch
I would be looking at the intake valve reliefs on all the rest of the pistons and the outside edge of all of the intake valves I see some non carbon build up near the edge of the two pistons in the picture Let us know what you find BTW I have several of those dang 426 Hemi pistons with valve damage in them, not from broken intake valves though I had to find out the hard way that the original street Hemi 426 stock exhaust valves did not like to be floated very much, in fact they hated being floated or over revved so much they would just fall apart
Re: Why would an intake valve break? [Re: Cab_Burge] #1250627
06/15/12 01:05 AM
06/15/12 01:05 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Cab,, I'm putting my coin on valve float. This is #6 that dropped. #8's pushrod was off the adjuster and up against the rocker. And yes, all my lash was dead on. I'm guessing the springs didn't like the RPM. So anyone have any aluminum heads for sale? May as well upgrade and drop some weight at this point right?
Re: Why would an intake valve break? [Re: fig426] #1250628
06/15/12 01:36 AM
06/15/12 01:36 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That's nasty, bad luck. Would it have done that much damage if it just happened when you started it to load up?
Re: Why would an intake valve break? [Re: fig426] #1250629
06/15/12 02:33 PM
06/15/12 02:33 PM
You have a PM
Re: Why would an intake valve break? [Re: fig426] #1250630
06/15/12 03:59 PM
06/15/12 03:59 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ouch
Been there, done that last year with our 477 Hemi. The cause on mine was over reving it in the water burn out, and that bent the valve. I zinged it, and didn't catch it in time. Then I staged and ran it down the track where the valve head broke right off and migrated thru a couple of cylinders.
I have also seen the seats drop out of the stock hemi heads for no reason, and the valve guides on a stock hemi are almost always over sized, not tight.
Re: Why would an intake valve break? [Re: Dragula] #1250631
06/15/12 09:01 PM
06/15/12 09:01 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Last time I dropped a valve in a Hemi, cost me one piston, Rod, hole thru cyl the head, nick out of the cyl wall and a bent crank...lost it in teh traps
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
