Re: 318 valve lifter question
[Re: plymguy]
#1250035
06/13/12 06:53 PM
06/13/12 06:53 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Try running a can of Rislone, Marvel Mystery Oil or even a QT of ATF in the oil. Usually intermitant lifter noise is caused by the lifter being dirty. The above products will help clean the varnish ect that makes them make noise.
I am truckless..
[Re: Dodgem]
#1250038
06/14/12 04:18 PM
06/14/12 04:18 PM
Posts: 15,487 Florida
scratchnfotraction
Often on 318's it's the pushrods are wearing down and the rockers? something to check!
I have found this to be correct most times as well. have had some lobes go south on older higher milage engines.
chased a lot of lifter noise to find it was only a exhast leak that would come and go as it heated up. could never hear it out under the hood but drove me nuts in the driver seat.
I have R&R the intake to get at the lifters then one by one open them up and clean them good with brake clean and stick them back in.
dip them in oil and drop them back in the same hole,fire it up and idle till they all pump up again. may take while some times to pump all the air out,but has fixed the ticking sound more than a couple times for me working on used engines from the JY.
you would be surprized at the solid crud/carbon that will build up in a lifter over time. kinda goes solid and tics.
just did a set of stock roller lifters last week for my stroker engine porject. had 2 that were clogged soild,but are clean and ready for service again.
