Re: Inexpensive 5140 Conn. Rods. Yes Or No ?
[Re: JohnRR]
#1249829
06/12/12 03:12 PM
06/12/12 03:12 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Who makes the Source rods? It says made in the USA?
Howards by chance? Or Ohio crank?
Where did you see made in the USA ?? The only thing that says that anything is made in USA is the ARP ROD BOLTS ...
Just skimmed the specs, and saw USA, new it couldnt be true for that price. Im a terrible skimmer.
[Re: meus31]
#1249833
06/12/12 05:34 PM
06/12/12 05:34 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
what is the best buy then ?
define BEST BUY ... K1 used to be a good buy for a chinese based rod , not so much anymore since it was sold , still a chinese sourced rod ...
[Re: meus31]
#1249834
06/12/12 05:42 PM
06/12/12 05:42 PM
Posts: 5,875 communist bloc of new jersey
jamesc
that's a very subjective question and opinions vary. frankly i personally don't care for any of the imported h beams and unfortunately manley wasn't making enough money of their sprotsmasters so they dropped them.
if i was in the market for rods similar to whats being discussed i would look into these. i know they're a lot more and people have successfully used cheaper rods but personally i won't roll those dice. still chinese but hopefully improved quality control and they should be the correct dimensions as they are (i believe) finished by callies. perhaps someone with experience with them can confirm or refute my thoughts
compstar
[Re: jamesc]
#1249835
06/12/12 05:52 PM
06/12/12 05:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was sorta fortunate that when Eagle H-beams first came out(maybe a year after they came out) I bought a set and had them checked and was very happy with them so I bought a second set that layed around for years... the first set is in my W-9 and the second set I just put in my W-5.... the W-9 has been in the 9000+ rpm range but normal is 8200.... now days I hear the quality of them is ... not very good
[Re: meus31]
#1249836
06/12/12 06:16 PM
06/12/12 06:16 PM
Moparnut426
Well if you think what is the best rod and figure in replacement cost in the factor, say you have a 5000 dollar engine, is it worth sticking a set of 300 dollar rods in it, NO, I guess My thinking is spend up to 1/4 the cost of the engine on the rods, that would make a 1250.00 dollar set of rods "in the market" so Id buy Olivers, or Some Manley or Crower billet stuff.
I didnt spend that much on my rods, but If i was to replace my rods with a like rod, it would be that much. I bought a set of unused Childs terackmaster rods off a member here, and IIRC those were up a grand when they still made them.
Kasey
