holley carb #1249768
06/12/12 12:14 PM
06/12/12 12:14 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
I had a carb rebuilt and it starts great idles great real responsive while it's in park but when you go to drive it it has a terrible dead spot at about 2000-2500 rpm that will kill the engine if you don't let off it and it deads out again at about 4000 rpm. I know very little about carbs so any ideas what it could be? it's a vacume secondary 750.
Re: holley carb [Re: Clayton] #1249769
06/12/12 01:21 PM
06/12/12 01:21 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do you have a vacuum gauge on it?
changed the sec vac spring?
What power valve is in it?
acc pump cam?squirter?
have you adjusted any of the above?
Re: holley carb [Re: Clayton] #1249770
06/12/12 05:16 PM
06/12/12 05:16 PM
I'd start by adjusting the float level(s) and check that the accelerator pump squirt amt/duration appears to be adequate
Re: holley carb [Re: RapidRobert] #1249771
06/13/12 11:34 AM
06/13/12 11:34 AM
P
Paul_Fancsali Offline
P
Did you check to see if anyone put the sec spring back into the vac pot? Also if the older model check ball is removed it will bog with a real light spring.
Re: holley carb [Re: Paul_Fancsali] #1249772
06/13/12 12:19 PM
06/13/12 12:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Id start by contacting the guy who built it before messing with anyrhing
