Re: what are the restrictions on a stock 904?
[Re: Jonnyj00]
#1249052
06/11/12 10:51 AM
06/11/12 10:51 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
we have a 904 hooked up to a stock 360 and it seems to do fine in a 64 valiant but the motor is getting tired and its getting time for a new motor. nothing extreme cause this is the car my 16 year old brother will take down the track. so what are the hp restrictions on a stock 904 with a deep pan ?
thanks guys!
Pretty much stock internals in mine.
[Re: Jonnyj00]
#1249053
06/11/12 10:58 AM
06/11/12 10:58 AM
dartman366
Mt. Vernon, Ohio
as long as the trans is in good mechanical condition the only thing I can say is in dead stock condition I would limit it to 400/425 hp there are things you can do to help make it better but that would mean getting into the case and changing the valvebody and adding a shift kit at the very least to help the clutch's and intermediate band lock up cleaner with a little more line pressure,,slippage is not good and the clutch's are not very big and slippage will kill them quickly, if you are using a kickdown linkage make sure it is adjusted dead on, that controlls the line pressure on a stock VB. ![](/ubbthreads/images/graemlins/wave.gif)
