440 block casting number identification number help #1248816
06/10/12 10:35 PM
06/10/12 10:35 PM
colorado
9
929lamasters Offline OP
colorado
I'm thinking about buying a 440 to make into a stroker motor but the casting number on the block is 3830930-440-8 or 3830930-440-b he not sure on the B or 8 can any one help me with this casting number? Also what year of block is this and what it may have come out of? Thank you for your help.
Re: 440 block casting number identification number help [Re: 929lamasters] #1248817
06/10/12 11:04 PM
06/10/12 11:04 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
8 - means 8 casting 'events' with that mold. No telling how many blocks were cast per 'event'. But someone might know what an average number of blocks cast per 'event'. 'Event' isn't the proper term, but it's all I can think of just now.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 440 block casting number identification number help [Re: amxautox] #1248818
06/10/12 11:06 PM
06/10/12 11:06 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
Tom would "event" be similar to number of pours per mold. Say number 8 on this mold?
Re: 440 block casting number identification number help [Re: TheBlueBeast] #1248819
06/10/12 11:07 PM
06/10/12 11:07 PM
amxautox Offline
amxautox  Offline
No, more like number of times the mold was 'rebuilt' so they could make more blocks.
Tom
author unknown
Re: 440 block casting number identification number help [Re: amxautox] #1248820
06/11/12 05:20 PM
06/11/12 05:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, the dash number is the number of core plugs changed in the casting core....highest number I've heard of is 13. Some think the higher the number, the higher the likliehood of core shift...never been proven.
Re: 440 block casting number identification number help [Re: John_Kunkel] #1248821
06/11/12 06:48 PM
06/11/12 06:48 PM
dogdays Offline
dogdays  Offline
Welcome to the world of Mopar castings. There are several things to note:
1. Any block can be a good one or a bad one. Casting quality is all over the board.
2. It is safe to say, keep the overbore minimal. More power can be lost to flexible cylinder walls than found by a few more cubic inches.
3. The only way to be sure of a particular block is to sonic check it.
4. The " '75 and newer blocks are thinwall" statement promulgated by official Mopar insiders is BUNK. Later blocks may be made of slightly softer material, but cylinder wall thickness isn't statistically different.
5. Mopar blocks are known to have decks that are not perpendicular to each other and/or not parallel to the crankshaft centerline.
6. It's been noted that many 400 blocks have seven good holes and one bad hole. Sleeving the bad hole is an acceptable option. Properly done, the sleeve is as good or better than the other holes.
7. Look at the pan rail to see if any marks there may indicate an oversize lifter bore. This has been known to happen although it's rather rare.
8. The "dash number or "casting core revision number" is no indication of how good a block is. Sonic testing has revealed that there are unusable blocks with a -1 number and super blocks with a -12 number.
9. I REPEAT, THE ONLY WAY TO TELL IF A BLOCK IS GOOD IS A SONIC TEST.
R.
Re: 440 block casting number identification number help [Re: 929lamasters] #1248822
06/11/12 07:27 PM
06/11/12 07:27 PM
AndyF Offline
AndyF  Offline
There will be a casting date on the side of the block as well as a VIN stamp on the oil pan rail. There is also ID info on the ID pad.
