What carb should I run? #1248681
06/10/12 07:28 PM
06/10/12 07:28 PM
NC
1970A66 Offline OP
1970A66  Offline OP
NC
Wondering if my current Holley 750 vacuum secondary carb is OK for my STREET car. Would something bigger or a DP make it run stronger?
70 Challenger, 3400 lbs, 4 speed, 3:55 rear, 340 stroked to 373. Engine dyno's at 420 hp.
10 to 1, cam: 231/237 @.050 w/525 lift, 10 inches vac at idle, Performer RPM intake ported to X heads, TTI headers to 2.5 pipes.
It runs good but I can't help wondering it it would like more air?
Re: What carb should I run? [Re: 1970A66] #1248682
06/10/12 09:17 PM
06/10/12 09:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
either should work fine. I fthe 750 vac is working just leave it.
Coming soon!!!!
Re: What carb should I run? [Re: Mr.Yuck] #1248683
06/10/12 11:34 PM
06/10/12 11:34 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
^ Mr yuck is right, if it runs well no need to change it, but if you like to, instead of getting a bigger carb, rent sometime on a chassis dyno and dial that 3310 series in on it! I picked up quite a bit just jetting and setting timing right.
Mike
1969 Dodge Dart Swinger
Re: What carb should I run? [Re: 1970A66] #1248684
06/12/12 05:35 PM
06/12/12 05:35 PM
NC
1970A66 Offline OP
1970A66  Offline OP
NC
Alright...thanks guy's for the replies, that helps!
Re: What carb should I run? [Re: 1970A66] #1248685
06/12/12 06:08 PM
06/12/12 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The DP will get you off the line quicker... the 750
was stock on a 340 so I'm sure more carb will make
more power... but is it worth it to you... borrow
a bigger carb and try it
