Where does this wire go? #1248393
06/10/12 02:40 PM
06/10/12 02:40 PM
Western NY
19SuperBee70 Offline OP
Western NY
Can't find it in the wiring schematics. Car is a 70 superbee. The orange wire is from the light for the heater controls. The second pic shows a 3 hole connector, is this where it goes?
Re: Where does this wire go? [Re: 19SuperBee70] #1248394
06/10/12 02:40 PM
06/10/12 02:40 PM
Western NY
Western NY
pic
Re: Where does this wire go? [Re: 19SuperBee70] #1248395
06/10/12 03:55 PM
06/10/12 03:55 PM
Pittsfield, Mass.
Russ_Davis Offline
Russ_Davis  Offline
Pittsfield, Mass.
I believe thats where it goes. Just take a test light and check that is the light connector. Turn lights on and off.
Re: Where does this wire go? [Re: Russ_Davis] #1248396
06/10/12 04:15 PM
06/10/12 04:15 PM
NJ
rth Offline
rth  Offline
NJ
i agree,multiple port plug for dash lights.
Re: Where does this wire go? [Re: rth] #1248397
06/10/12 04:18 PM
06/10/12 04:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
x3
Re: Where does this wire go? [Re: JohnRR] #1248398
06/10/12 04:25 PM
06/10/12 04:25 PM
Western NY
Western NY
Thanks. I can't test, the rest of the wiring is disconnected. I converted my ammeter to a voltmeter and need to change some other wires around before I hook up the battery. now for the radio wiring...
Re: Where does this wire go? [Re: 19SuperBee70] #1248399
06/10/12 05:19 PM
06/10/12 05:19 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
pretty sure the map light and the ign switch delay lamp also plug into that. i could go check if need be?
Re: Where does this wire go? [Re: mikemee1331] #1248400
06/10/12 05:44 PM
06/10/12 05:44 PM
Western NY
Western NY
Sure, if you could. I'll check and see where my map light is currently wired.
Re: Where does this wire go? [Re: 19SuperBee70] #1248401
06/10/12 06:37 PM
06/10/12 06:37 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
looking like heater light, ash tray light and radio light. don't hold me to that as it's a snakes nest under there but the wiring diagram looks that way too.
