Re: 6-pak throttle position adjustment
[Re: tcat446]
#1248010
06/09/12 08:20 PM
06/09/12 08:20 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Hello all !!
First post here. Can anyone tell me how to go about adjusting a throttle sensor bolted to the manifold on my 70 Cuda 6 pak? Thank you in advance. Looks like a nice site!!
Welcome aboard! are you referring to the idle solenoid under the center carb linkage?
[Re: mikemee1331]
#1248011
06/09/12 09:47 PM
06/09/12 09:47 PM
Posts: 295 FLA
JohnnyBee
FLA
[Re: mikemee1331]
#1248012
06/09/12 10:29 PM
06/09/12 10:29 PM
Posts: 123 Ripley, NY
tcat446
Ripley, NY
Hello all !!
Yes, I am. It doesn't move when the key is on. Is it suppose to?
[Re: tcat446]
#1248015
06/09/12 10:40 PM
06/09/12 10:40 PM
mikemee1331
bethlehem pa
Hello all !!
yes, it is. here is a link to a link that has alot of great info and a truly awesome website. https://board.moparts.org/ubbthreads/showflat.php?Number=6940589
[Re: mikemee1331]
#1248019
06/10/12 11:34 AM
06/10/12 11:34 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
it's 12 volts and doesn't have a seperate fuse. i would run a test wire from your battery and bump the power terminal to verify it's working.
And if it has power it still wont work unless the throttle is open enough to take pressure of the plunger.The solenoid wont lift the arm,it is designed to hold the arm up after the arm is lifted and solenoid engaged.
