brake booster check valve... #1246983
06/07/12 05:22 PM
06/07/12 05:22 PM
Cincinnati Ohio USA
Moeggenpar Offline OP
Cincinnati Ohio USA
I'm replacing the valve.Does it just pull straight out?Is there any trick with installing the new one? Thanks for any help
Re: brake booster check valve... [Re: Moeggenpar] #1246984
06/07/12 05:30 PM
06/07/12 05:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
grab a firm hold, and with a twisting motion just pull it out
