Re: Cam Help Please!!
[Re: chris3]
#1246526
06/07/12 08:50 AM
06/07/12 08:50 AM
Posts: 622 NC
chris3
NC
Thanks for the information guys. Are your racing Hydraulic, Mechanical or roller? Any more recommendations?
[Re: chris3]
#1246527
06/07/12 10:23 AM
06/07/12 10:23 AM
Posts: 1,532 off the grid
340B5
off the grid
My 340 w/J heads liked the STH-42(Hyd. version of the ST-21)
I'm putting the same one in my 374.
Yeah, it's got a smallblock.
[Re: chris3]
#1246530
06/08/12 12:24 PM
06/08/12 12:24 PM
Triple Threat
Renton Washington
If you're willing to change the springs and such a roller will make more power.
If you want to keep your current valve springs that will dictate how aggressive you can get with your camshaft. Run good oil with whatever you choose.
[Re: Triple Threat]
#1246531
06/08/12 12:51 PM
06/08/12 12:51 PM
The Comp solid grind that is 255 @050 intake and ex is one of the best small block stock type head cams out there for 1/8th mile it is amazing! I put it in a 360 at 103 and it will yank the spit out of your mouth on the leave. Think it is 540 lift--a REALLY good grind. My old heads maybe flowed 225 intake so nothing great and my Duster would run 6.90 1/8 ths and that was with an RPM dual plane--It would have all it wanted in a 1/4 mile run and would have liked an open intake but for 1/8th it was just killer! 106 LSA so in at 103 and it sounded like a top fuel car at idle, I always used 1.5 rockers -- Rollers in a SB can be a Pain--ask around about what lifter will fit the block and if you have stock length valves you really have to sink spring pockets , use 10 degree titanium retainers, etc to get a decent spring on it as installed ht is so short
