Cam Help Please!! #1246520
06/06/12 10:30 PM
06/06/12 10:30 PM
NC
chris3 Offline OP
chris3  Offline OP
NC
71 340 bored 30 over with JE Domed Pistons. "J" big valve heads with shaft roller rockers. What is the mechanical and roller of choice. Been running 590 Mopar. Looks like a bad lobe. There are so many on hear with some good advise I will appreciate and consider everyone's opinion. Thanks for the help.
Re: Cam Help Please!! [Re: chris3] #1246521
06/06/12 10:52 PM
06/06/12 10:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Got any idea what the heads flow and what rpm do you
plan on turning
Re: Cam Help Please!! [Re: MR_P_BODY] #1246522
06/06/12 11:41 PM
06/06/12 11:41 PM
NC
chris3 Offline OP
chris3  Offline OP
NC
They are 915 "j" heads with some home port clean-up. Typically 6500 through the lights.
Re: Cam Help Please!! [Re: chris3] #1246523
06/07/12 12:27 AM
06/07/12 12:27 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Its hard but try not to over cam. My sons street legal duster (360)runs 10.50's and my 408 duster (strip only) ran a 9.98 and both are using a 520 solid cam from Racer Brown.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cam Help Please!! [Re: pittsburghracer] #1246524
06/07/12 12:35 AM
06/07/12 12:35 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
just curious if that's the ST-21?
Re: Cam Help Please!! [Re: jamesc] #1246525
06/07/12 12:50 AM
06/07/12 12:50 AM
PA.
"Little"John
"Little"John
PA.
Yes it is in my sons car but Jim like to play around with his grinds if you give him flow numbers at every.050 and compression numbers. I have 4 of his cams right now. Here are the numbers for 3 of them. No secrete on the 4th but the card must be in my shop.
ST-21
ST-21/ST-24
ST-24/STX-19
Jim Dowell is a great guy and usually keeps me in line lift wise. I really like pump gas builds and until I go compression nuts these seem to work well.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cam Help Please!! [Re: chris3] #1246526
06/07/12 08:50 AM
06/07/12 08:50 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
Thanks for the information guys. Are your racing Hydraulic, Mechanical or roller? Any more recommendations?
Re: Cam Help Please!! [Re: chris3] #1246527
06/07/12 10:23 AM
06/07/12 10:23 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
My 340 w/J heads liked the STH-42(Hyd. version of the ST-21)
I'm putting the same one in my 374.
Yeah, it's got a smallblock.
Re: Cam Help Please!! [Re: chris3] #1246528
06/07/12 12:08 PM
06/07/12 12:08 PM
PA.
"Little"John
"Little"John
PA.
Don't be afraid of running a small solid lifter cam on the street. Use a good oil like Brad Penn and a oil additive like Comp Cams (#159) and the recommended spring pressure. My valves rarely need reset but are checked as routine maintenance. If you want to talk to Jim Dowell at Racer Brown his number is 410-866-7660.
Call him late afternoon into the evening eastern standard time.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cam Help Please!! [Re: pittsburghracer] #1246529
06/08/12 10:15 AM
06/08/12 10:15 AM
NC
chris3 Offline OP
chris3  Offline OP
NC
Thanks for the reply and the Duster is a race car only no street time.
Re: Cam Help Please!! [Re: chris3] #1246530
06/08/12 12:24 PM
06/08/12 12:24 PM
Renton Washington
Triple Threat Offline
Renton Washington
If you're willing to change the springs and such a roller will make more power.
If you want to keep your current valve springs that will dictate how aggressive you can get with your camshaft. Run good oil with whatever you choose.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Cam Help Please!! [Re: Triple Threat] #1246531
06/08/12 12:51 PM
06/08/12 12:51 PM
The Comp solid grind that is 255 @050 intake and ex is one of the best small block stock type head cams out there for 1/8th mile it is amazing! I put it in a 360 at 103 and it will yank the spit out of your mouth on the leave. Think it is 540 lift--a REALLY good grind. My old heads maybe flowed 225 intake so nothing great and my Duster would run 6.90 1/8 ths and that was with an RPM dual plane--It would have all it wanted in a 1/4 mile run and would have liked an open intake but for 1/8th it was just killer! 106 LSA so in at 103 and it sounded like a top fuel car at idle, I always used 1.5 rockers -- Rollers in a SB can be a Pain--ask around about what lifter will fit the block and if you have stock length valves you really have to sink spring pockets , use 10 degree titanium retainers, etc to get a decent spring on it as installed ht is so short
Re: Cam Help Please!! [Re: chris3] #1246532
06/08/12 12:59 PM
06/08/12 12:59 PM
Redding,CA USA
440charger500 Offline
Redding,CA USA
Check out the lunati voodoo 60442 solid cam. Makes big power
Re: Cam Help Please!! [Re: 440charger500] #1246533
06/08/12 02:06 PM
06/08/12 02:06 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Call these guys and see what they recommend.
Im very happy with their solid flat tappet. It picked up ET over a similar Scott brown cam.
http://www.hughesengines.com/Index/index.php
