how is steel fuel line measured ID or OD #1246514
06/06/12 10:28 PM
06/06/12 10:28 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
If you purchase a 3/8 metal fuel line from any one of the venders, year one, fine lines, etc. is the 3/8 ID or OD
Re: how is steel fuel line measured ID or OD [Re: frank] #1246515
06/06/12 11:03 PM
06/06/12 11:03 PM
OD and the neoprene hose that slips over it is measured in ID
Re: how is steel fuel line measured ID or OD [Re: RapidRobert] #1246516
06/07/12 12:28 AM
06/07/12 12:28 AM
Bigger is better on the I.D. of the fuel line
Re: how is steel fuel line measured ID or OD [Re: frank] #1246517
06/07/12 09:19 AM
06/07/12 09:19 AM
tucson az
frank Offline OP
frank  Offline OP
tucson az
So when you order a 3/8 fuel line what you are really getting is maybe 5/16 ID. if that.
Re: how is steel fuel line measured ID or OD [Re: frank] #1246518
06/07/12 01:13 PM
06/07/12 01:13 PM
dogdays Offline
dogdays  Offline
The size of tubing is always OD.
I wouldn't get worried about the fact that the ID is smaller than that. A rule of thumb for fuel use is 0.5 lb fuel per horsepower hour. So if you have a 400 hp engine on the dyno it will burn about 200 lb fuel per hour. Gasoline is around 7 lb per gallon so that's about 19 gallons per hour at max output. I think the tubing will allow that with minimal pressure drop.
R.
Re: how is steel fuel line measured ID or OD [Re: dogdays] #1246519
06/07/12 06:05 PM
06/07/12 06:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The metal fuel line is measured in OD. The rubber fuel hose is ID.
