drilling holes in pistons #1246359
06/06/12 05:48 PM
06/06/12 05:48 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
when drilling holes at the top of the pistons (compression pushes rings outward for a better seal)what size hole and do you drill down to the second ring also or just the top ring
Re: drilling holes in pistons [Re: moparmikethree] #1246360
06/06/12 06:03 PM
06/06/12 06:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Never seen them on the second ring.... I would have
to look at a spec sheet to see what size hole they drill
Re: drilling holes in pistons [Re: moparmikethree] #1246361
06/06/12 10:09 PM
06/06/12 10:09 PM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
.040-.050 dia You want to drill them at an angle but if this is your first time drill them vertical.You want to hit the back of the ring land .Measure piston dia and ring land dia.Us the quill stop and move it 1/4 turn per poke or uall have some broken drills in your holes.Buy 1 drill for every 5 holes to be safe.dont wait till one gets dull.Or youll push a burr in the ring land and or break a drill that costs less than a buck or two.Use Cobolt drill not cheap HSS
Re: drilling holes in pistons [Re: moparmikethree] #1246362
06/07/12 01:35 AM
06/07/12 01:35 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
You should always think of the rings like this. The top ring is compression, the second is a scraper and the third basically oils your wristpin. If compression gets past the top ring, it's best that it gets past the second ring too because if pressure gets between the top and second rings, the top ring will become unseated and will basically be along for the ride only. My point being, only drill to the top ring groove.
Re: drilling holes in pistons [Re: dodgeboy11] #1246363
06/07/12 01:49 AM
06/07/12 01:49 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
this is why sealed power recommends opening up the second ring gap
