drilling holes in piston #1246348
06/06/12 05:42 PM
06/06/12 05:42 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
when drilling holes in the top of the pistons at the top ring.(compression pushes the ring out for better sealing) What size drill bit, and do you drill down to the second ring also
Re: drilling holes in piston [Re: moparmikethree] #1246349
06/06/12 05:58 PM
06/06/12 05:58 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My is to do a Google search on "gas porting pistons" and spend some time looking at the articles & tool links that come up.
Re: drilling holes in piston [Re: BradH] #1246350
06/06/12 07:34 PM
06/06/12 07:34 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Is that procedure even done anymore? I remember it from years ago but nothing in the last few years..
I am truckless..
Re: drilling holes in piston [Re: 340SHORTY] #1246351
06/06/12 07:41 PM
06/06/12 07:41 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I bought my 440 from a member here and the pic of the block with the heads off shows a hole in the center of each piston.
Scott
1969 Super Bee, 383/4 speed
Re: drilling holes in piston [Re: StukaJU87] #1246352
06/06/12 07:45 PM
06/06/12 07:45 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Scott
Re: drilling holes in piston [Re: StukaJU87] #1246353
06/06/12 08:14 PM
06/06/12 08:14 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
That is a machining dimple from centering the piston. I would hope it does not go all the way through.
To the OP, if you don't know what you're doing, gas porting is a very quick way to ruin a good set of pistons. Google will be your friend for sure.
Re: drilling holes in piston [Re: slantzilla] #1246354
06/06/12 11:30 PM
06/06/12 11:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what he said
Re: drilling holes in piston [Re: moparmikethree] #1246355
06/07/12 12:27 AM
06/07/12 12:27 AM
All gas porting, vertical or horizontal, should be done by a competent Hi Po shop or a piston company with the proper equiptment, not a piston vice and drill motor
Re: drilling holes in piston [Re: Cab_Burge] #1246356
06/07/12 03:38 PM
06/07/12 03:38 PM
Toronto, ON
ehbody Offline
ehbody  Offline
Toronto, ON
Stupid question.
But what does "gas porting pistons" do?
Shawn 70 AAR
Re: drilling holes in piston [Re: moparmikethree] #1246357
06/07/12 03:54 PM
06/07/12 03:54 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I gas ported a set of motorcycle pistons years ago, but they tell me that the way rings are made today it's not needed. Talk to a motor expert.
Re: drilling holes in piston [Re: ehbody] #1246358
06/07/12 03:57 PM
06/07/12 03:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Stupid question.
It puts compression pressure behind the ring forcing it against the piston and the bore for a better ring seal. I have a set of JE pistons that had it done. Only negative thing is once the holes get filled with carbon it's the same as a piston with no holes drilled.
