Re: Port Matching Exh ports on 340/360 heads
[Re: domingo]
#1246166
06/06/12 12:55 PM
06/06/12 12:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
suggestions on how to make the short turn better?
Do I risk hitting any water jackets? Places to watch out for thin spots? How much can I poen them up all around? 0.060"?
Behind the short turn is water.... just make that a bigger radius... the top has a pretty sharp edge that needs a better radius... basically your trying to make a straight run out of it(but you cant)
[Re: domingo]
#1246168
06/06/12 01:09 PM
06/06/12 01:09 PM
MR_P_BODY
Thanks!
and how can larger can I make the ports all around? How much is safe?
Dont know a number but dont go stupid on the bottom short turn or the top where the spring is on the top
[Re: MR_P_BODY]
#1246169
06/06/12 02:03 PM
06/06/12 02:03 PM
dogdays
DO NOT port match the bottom 1/3 of the runner. It may even decrease flow.
Any port matching will be worthless unless you open up the valve bowl. That's the choke point.
On the exhaust side you want to leave the port a little smaller than the gasket and then make the header or exhaust manifold slightly larger than the gasket to give you a step to reduce reversion. But don't touch the bottom of the port window!
Look up articles about porting LA heads on the internet. There is a wealth of information out there, some of it true.
R.
[Re: domingo]
#1246174
06/06/12 06:56 PM
06/06/12 06:56 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Don't enlarge the exhaust port at the exit, at all. The later the head casting, the better.......... (894, 915, 587, 974, 596, 051, 308)
Short turn is non-exsistant on early heads. The best you can do is "roll" as big of a radius on it as possible off the seat. Don't cut EGR bumps out of the floor but, if they are drilled, plug them. (late heads)
[Re: S/ST 3040]
#1246175
06/07/12 02:45 PM
06/07/12 02:45 PM
Posts: 2,128 sweden
sshemi
sweden
why wouldnt he want to make the port bigger at the exit???
[Re: sshemi]
#1246176
06/07/12 10:42 PM
06/07/12 10:42 PM
Posts: 235 Glendale, AZ
Dave W
Glendale, AZ
What head porter is best known for obtaining the most power potential out of a factory set of small block heads? This video is very impressive! Does anyone know the details on this paticular combination? 644 hp with modified stock heads, intake, carb, exhaust manifolds while running the factory air cleaner assembly...that is AWESOME! http://www.youtube.com/watch?v=I1gswAFxcBc
[Re: Dave W]
#1246178
06/08/12 08:44 AM
06/08/12 08:44 AM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Thanks for the compliment, I ported the heads and intake, Scott Koffel did the valve job and final blend to the seat. The motor is apart at the moment and as a matter of fact I am making a slight change to the intake short turn.
On the exhaust gasket match, the 308 exhaust has a really nice short turn and port shape in general. I would do a clean-up on the runner. Raise it to the gasket and widen it just to clean up. After cleaning up the short turn dont make it any lower just to match a gasket(I would not go all the way to the gasket shown on the width, especially the shared wall of the two center ports, but I dont think you would hit water).
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#1246179
06/08/12 09:28 AM
06/08/12 09:28 AM
Dave W
Glendale, AZ
Thanks for the feedback. Are you running a 800cfm thermoquad and is that the current set-up in your Duster?
